Question about Shoprider Mobility Products, Inc. Hero 3-Wheel Scooter with Swivel Seat and Curved Tiller Blue 1ea
How to get the overload button back out on a mobility scooter
My scooter will go a reasonable distance and then it loses power like the batteries are low, but if you switch off and leave for a while it's back to normal again.
The controller can be overheating.... going up too long or overloading the weight limit(too much stuff in the basket)
Sep 18, 2016 | Health & Beauty
Gears not engaging properly
If it is the typical worn motor and the scooter is over 5 years old you are better off buying a new scooter.
Gears rarely go bad unless they were overloaded. It's usually the motor that wears out and is intermittent before it goes.
Oct 16, 2013 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Electrical shuts off or slows down when riding
You may need to replace the battery even though it is charging. It sounds like a bad battery or the motor may be overloaded.
May 06, 2012 | Pride Mobility Products Legend 3-Wheel...
Why does my scooter drives for 10 to 15 feet then kicks the reset switch
Hello John.CIRCUIT BREAKER TRIPS FREQUENTLY.Possible Cause:Overload caused by exessive demand on motors (low tire pressure,sticky brake,seized wheel bearings etc).
Heavy load on steep incline.
Loose batteries terminal connections.
I hope this will help you get mobile again,have a nice day.
Oct 30, 2011 | Health & Beauty
My battery is full charge.when press to go forward it goes about two feet and locks up. the wheels will not turn. i need help bad. i have a shoprider hero modelsl73n
According to the Owners Manual: Circuit Breaker (Reset Button)
Your scooter is fitted with the latest in electronic controls that are programmed to protect
the electrical system from abnormal overloads. Provided for extra protection is a circuit
breaker, located on the battery pack. Should there be a situation where your scooter stops
for no apparent reason, please check that the circuit breaker has not popped.
If you have misplaced your Owners Manual, here is a link to one. It may not be the exact model you have (as, your Model # was not recognized), but they all work pretty much the same way.
http://www.scooter.com/files/Shoprider_Echo_manual.pdf
Hope this helps to get you scooting along, again.
Mar 18, 2011 | Shoprider Mobility Products, Inc. Hero...
The scooter was working fine my father added weight to the foot plate shopping now it wont drive its a shop rider
Check your breaker ,its right there on the footboard ,If the chair may have been overloaded it may have pop your breaker.
good luck sir ,
Jan 23, 2011 | Pride Mobility Products Pride Mobility...
Overload
Check your fuses, replace if they are blown.
Oct 13, 2010 | Electric Strider Maxi 4 Wheel Mobility...
Celebrity XL4, when going up hill, power cuts out. turn key off and back on, scooter will go again for a couple of feet.
Sounds like Overload Cutout ??? Use a Higher Rating Cutout, as going up hill is very hard on Scooters and it also depends on your weight.
Gerry
Aug 11, 2010 | Pride New Mobility Victory XL 4 Wheel...
Shoprider Mobility Products, Inc. Hero 3-Wheel Scooter with Swivel Seat and Curved Tiller Blue 1ea Logo
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
