Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Cannot connect wireless on Advent 4311c using xp
I have a zoom router, when connect to pc via ethernet cable it connects no problem, it will also connect to Dell laptop running Vista but wont connect to avent netbook 4211c running XP. The Netbook finds the wireless conection and attempts to connect for a few minutes then stops without any error msgs - have also tried turning of the windows firewall before connecting but no luck Any ideas??
  • 3 more comments
  • emmaburns81 May 22, 2009
    It was unsecured at first but It did not find it at all when unsecured so changed it to WEP key and netbook can now find the network but would not connect. It says connecting . . . .then closes with no msg to say what the problem is.
    The wireless card has no error on device manager either.
    Router has no mac address entered
    Have another wireless laptop that found and connected no problem, with WEP key and the netbook will connect through ethernet cable.
    Thank-you Ill head down to nearest wifi spot later on and let you know,
  • emmaburns81 May 23, 2009
    Thanks for all your help, was a netbook problem and sorted now.
  • Carlos Soto
    Carlos Soto May 11, 2010
    OK, next step would be to try and connect this Avent laptop to another router, say a free wi-fi @ Sheetz or Panera or some nearby hotel that offers free wi-fi. This will test out the card and the Avent laptop to see if you can connect. It doesn't sound like it is your router since you said another laptop connected wirelessly to the router.
  • Carlos Soto
    Can a different laptop or wireless device log onto that Zoom router? If not, login to the routers admin section and verify that the router has not been locked into only allowing certain MAC addresses. If all else fails, reset the router back to factory default and try again, but try before setting up your security. Once the Avent connects, then go back and secure your router (which of course means that you must reconfigure the Avent to connect to the now secured connection). Good luck.
    Scholar:
  • 149 Answers
Glad you could work this out, happy everyone directed you to the correct solution.
Posted on May 23, 2009
I want to connect to a wireless router with my laptopbut dont seem to the wireless drivers.i have tried to connectwith virgin media modem and router .followed all instructions and when i remove ethernet...
Sir, try downloading the wireless driver from your laptop company's website. Or form the drivers cd/dvd they provided you. Then you can connect to any wireless capable modem/router from your laptop.
The ethernet cable provides the internet pulses into your laptop. If you remove it, your internet connection gets disconnected.
Jun 30, 2010 | Advent Netbook
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
Can't get the printer to print while connected to a router
Hi! I will be glad to assist you in this issue. This is the link that will help you to fix the issue:
1. Installing the Product Software in Windows XP and Vista for a Wireless Network Connection (Using an Access Point)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01736948&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
2. Installing the Product Software in Windows XP for a Wired (Ethernet) Network Connection
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01708573&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
3. Installing the Product Software in Windows Vista for a Wired (Ethernet) Network Connection
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01710137&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
4. Wireless & Network Issues Link:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=33412&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
Oct 25, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
My XP computer is a wired connection to the modem. The XP computer is supposed to be a wireless connection to the modem. That said, why is it that when setting up the router, I am instructed to plug in...
It's not really required to plug in your PC via ethernet cable to the wireless router in order for you to configure it. It is however, recommended to connect it via ethernet cable initially so that when you changethe wireless settings on the router you wont get disconnected. Please note, that when you connect your PC wirelessly all wireless settings should match (Wireless Name/SSID, Wireless Security (WEP/WPA keys or passphrase), Wireless MAC Filtering).
Jul 14, 2009 | Linksys WRT54G2 Wireless Router
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
I have just bought an ADVENT 4489
If you press Fn and F11 it will enable the wireless connection. Hope this helps :-)
Dec 06, 2008 | Recoton Advent Advent Q2035A 20" TV
Zoom aDSL modem/wireless router seen but not connecting
Here are a couple of ideas to look at first, assuming you haven't tried them already:
1) Does moving the router help? Sometimes a new DECT phone or a microwave, or even a piece of equipment at a neighbour's house, can interfere with the signal.
2) Does changing the channel on your router help at all? If there are many other networks using the same channel, this might block your own signal.
3) If this does not make any difference, it might be worth checking your security settings.
Nov 14, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Connection - Zoom Wireless-G AP+4, model 4401
Cathy I have the same make and model maybe I can help. I speak both Tech and Non Tech so stop me if I lose you.
1. Did you go through the set up process of first connecting to your wireless router through the cable provide via your PC/Laptop?
2. Congfiguring your wirless via your browser http://10.0.0.200 ?
Sep 14, 2008 | Zoom (56600000) Router
Wireless configuration
What you will need: Wireless router and a wireless adapter connected to your PC. This is assuming you have a broadband internet connection. Install the wireless router by taking the ethernet cable out of the back of your computer and placing it in the WAN or internet port in the back of your router. Install the wireless adapter inside your PC. Unplug your modem for a minute or so. Then plug in your modem and your router, then turn on your PC. If you are running XP, it should see a list of wireless access points you can access. Select the one for your router (should be the strongest) and hit connect. This will connect you to the wireless router and the internet. Note this solution assumes the following: You have a high speed internet connection, your ISP's modem is connected to your computer via an ethernet cable, and you are running windows XP.
May 19, 2007 | RCA DCW615R Wireless/Cable Modem
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
283 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
