Question about Sharper Image Electric Wine Opener - WSI-OP200
Opener will not lift cork out of bottle
I insert the opener and it goes into the cork. It just won't remove the cork from the bottle
How can I replace a pig tail on a bottle opener
The following seems to work, but might be tough if you don't drink the wine first. http://www.youtube.com/watch?v=5Y82j3R7tXw
Jul 02, 2014 | Home
Won't pull cork out
Battery may be soft. N/G
If it goes in with No Problem and will not pull out
May 21, 2014 | Waring Pro WO50 Cordless Wine Opener
Waring wine opener wont pull out cork
We learned that NONE of these electric wine openers like the new "plastic" corks. Take a needle nosed plyers and hold the cork tightly(as it sits inside the housing) and gently push the button to release the cork. it should work.
Apr 14, 2012 | Sunbeam Kitchen Appliances - Others
How do I open a bottle of wine without a wine opener?
You can push the cork into the bottle and extract it by using a cloth napkin inserted
into the bottle. It pinches against the cork and allows it to be pulled back out.
There may be a video on youtube about this.
May 03, 2011 | Microwave Ovens
Cork is stuck in Oster open and will not come out the usual wayl
Use a screwdriver (or whatever) to push the inner ring at the opening as far inside the appliance as you can. It is a black piece with a spring action that has plastic molded ridges inside. The ridges on the inner edge of this will grasp the cork. Then, while you are holding the inner section in place as far inside as possible, push the button to operate the opener and the cork should come out as it normally should. I had half a cork stuck up there, and this just worked perfectly.
Mar 29, 2011 | Sunbeam Oster Electric Wine Bottle Opener
I have an Oster Electric wine opener. I have half a cork stuck in it that won't come out....any suggestions??
Feb 21, 2011 | Sunbeam Oster Electric Wine Bottle Opener
A cork is stuck in my Oster Electric Wine Bottle Opener.. It spins and spins but will not move up or down. How can I fix this?
We had the same problem, and we took the thing apart, unscrewed the cork from the corkscrew and put it back together. You have to make sure you line everything up properly inside, though. There are contact points that need to be lined up on the inside.
Dec 28, 2010 | Sunbeam Oster Electric Wine Bottle Opener
Sharper Image Electric Wine Opener - WSI-OP200 Logo
67 people viewed this question
Top Sharper Image Home Experts
Tom Chichester
Are you a Sharper Image Home Expert? Answer questions, earn points and help others
