Question about Vehicle Parts & Accessories
Need price for new waterpump for 1996 mazda 626ls
I need to know the approximatw price for a water pump for a 1996 mazda 626ls. Possibly a timing belt as well.
  • 2,984 Answers
For the water pump: 4 cyl-$36.00/V-6-$44.00
For the belt: 4 cyl-$44.00/V-6-$49.00
Posted on Jan 04, 2014
1996 jetta waterpump replace
The camshaft timing belt and all the other belts need to come off first. as well as passenger side wheel. there are lots of bolts that need to be loosened to get to water pump and on water pump itself, about a 3hour job
Oct 11, 2012 | 1996 Volkswagen Jetta
How difficult to change the water pump? Should I assume just releasing the fan belt, 4 bolts and it's off?
found this from answers.com.....1. Depressurize and drain the cooling system. 2. Loosen the alterantor adjustment and remove the belt. 3. Remove the water pump pulley. 4. Remove all the timing belt covers. 5. Loosen the timing (camshaft) belt tensioner and slip the timing belt off the camshaft toothed pulley (ensure you do not move the positon of the camshaft) 6. Unbolt the lower radiator hose fitting and heater retrun pipe. 7. Unbolt the waterpump from the block (5 bolts). 8. Remove all traces of the old gasket before mounting the new pump (Permatex spray on gasket remover works well). 9. Install the new pump and reassemble in reverse order to above.
Jul 28, 2010 | 1991 Mazda 323
Timing belt installation
If you need instructions, do yourself a favor and have it repaired by a shop that works on Mazda's. You will want to replace the water pump and oil seals. its not a job for Backyard Bob.
May 09, 2010 | 1996 Mazda 626
Got a 2000 millenia s it knocks sounds like its
sounds like the water pump bearing is worn out and has detroyed the water pump shaft seal.
coolant is leaking thru the seal area ,due to the bearing worn out --hence throwing the water pump pulley out of alignment.
The water pump pulley runs of the timing belt.---hence the knocking --either from the pulley or belt chaffing against the timing cover or even throwing the engine timing a few degrees off.
Need to replace water pump and timeing belt and anything else that may be damaged.
That's why, when ever you do a timing belt always do the water pump too.
Dec 28, 2009 | 1999 Mazda Millenia
Whare is the waterpump?
follow bottom radiator hose and it will lead to it. It is on front of motor.
Nov 13, 2009 | 1996 Plymouth Voyager
Instructions to replace water pump on 2000 Mazda Precidia
Jul 31, 2009 | Mazda MX-3 Cars & Trucks
Cost to replace waterpump on mazda 626 1996
Go to (repairpal.com) and enter all your info & pick repairs for pricing in your area.
May 03, 2009 | 1994 Mazda 626
Te magna waterpump changeover
MAGNA 1996 TE you have to pull down all covers of front of motor remove rh wheel and inner plastic protecters to access crank wheel remove crank wheel. rh engine mount and two outer belts lower/lift engine to remove timing belt pulleys ect.remove timing belt to access waterpump lots of labour can email photos if any one needs an idea .of whats involved when replacing water pump. best get a timing belt kit and replace belt ,pulleys as well. then good for 100.0000 kms and plugs as well platium ones by doing on your own can save 800 to 1000 dollars just be carful not to move pulleys on timing belt . good luck i posted this after i had no response .a desiel mechanic guided me though the ordeal a lot of labour for a waterpump it took me 8 hrs straight to do . hope this is useful i didnt need timing kit just belt total cost if you do job $350.00 i got quoted $1500 by mechanic
$25 COOLANT
$300 TIMING BELT KIT OR $100 FOR BELT ALONE
$95( WATER PUMP NON GEN SUPERCHEAP AUTO)( GENUINE MITS $300 TOO MUCH$$$)
$90 PLUGS PLATIUM
$30 OIL
$7 OIL FILTER
$10 GASKET GLUE
Apr 01, 2009 | Mitsubishi Diamante Cars & Trucks
Timing belt/waterpump
usually a good time to change it is at about 100,000 miles. change it before it becomes a must or not ride(type of thing). if your water pump is run by your timing belt, then yes you should change the water pump when you do the timing belt. the tension from the new belt will sooner than later kill the bearing in the old water pump and it will cost you twice to fix it versus the one time fix. when you go in to the shop there should be no additional cost to replace the timing belt because it has to come off to replace the water pump.
Sep 22, 2008 | 2002 Mazda 626
Does the water pump have to be replaced with the timing belt?
teh resaon he wants to replace your water pump is because it runs off of your timing belt.and if it should fail later down the road after belt replacement.then you will be looking at another big expense having the same job done twice.i would rcomend you do get the waterpump replaced also.as for you other problem im not sure. samboiv
Jun 19, 2008 | 2000 Mazda Protege
Vehicle Parts & Accessories Logo
66 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
