Question about Canon imageCLASS D1150 All-In-One Laser Printer
Cannon D1150, document feeder will pull paper to copy but will not feed paper to scan?
5 Suggested Answers
xerick
  • 139 Answers
SOURCE: The paper feed wont stop
the paper picking rollers i think r weak try cleaning the rollers n try it again.
thank u
Posted on May 26, 2008
SOURCE: Check Document
Look at the sensor arms on the feeder cover...open feeder,and take it off from the sides..there are little wings that pop out of socket, and look at the black toggle arms... one most likely is dislodged...make sure they all toggle freely...ckeck the one towards the bottom first...if you have to , take screws out and pull cover apart to re-insert toggle arms....
Posted on Dec 12, 2008
Dicedonions
  • 118 Answers
SOURCE: the feeder on the top of my d1150 will not accept
turn on/off, unplug, plug in, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck preventing from accepting paper.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Posted on Apr 29, 2010
SOURCE: Documents will not feed from the ADF
Is there a more permanent fix in the meantime? I'm just tired of fiddling each time that I use the ADF
Posted on Jul 10, 2010
The feeder on the top of my d1150 will not accept paper it keeps jamming, i have been scanning alot of documents the last two days and now it will not scan anything, it keeps jamming
Apr 29, 2010 | Canon imageCLASS D1150 All-In-One Laser...
Cannot print double sided
On the machine when a 2 sided document is inserted in the document handler, select the 2x2 button on the console. Press the start button and the machine will feed the document in, and do a reverse of the document for the second scan. In the paper feeder, the machine feeds the paper in and reversed the copy back into the machine, flips the copy then feeds the copy back for the second side to be copied.
If you do not have a m20i, the lower model numbers will not do two sided copies.
Aug 14, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Copies run through feeder distorted
Document feeder Paper feed rollers should be cleaned with alcohol, blow out the document feed area with compressed air (computer duster), check feeder for bits of paper, post it notes, and signature flags. Clean glass, check for sticky areas on the glass.
Hope this is of some help.
Ed
May 12, 2009 | Toshiba E-Studio 3511 Color Copier
Document Feeder won't work
hello! check and look to see if there is anything blocking the paper feed area, if all is good, get some denatured alcahol and clean the paper feed roller as it may have a build up of paper dust good luck brother sr tech
Jan 14, 2009 | Brother MFC-8460N All-In-One Printer
Document Feed
first u switch off and switch on the machine, that time ur document feeder get rotating its not feeder problem. otherwise pls u check ur feeder driveres.
Jul 23, 2008 | Office Equipment & Supplies
Muratec F-520
It could have something to do with the automatic document feeder. There could be something in there that is blocking the paper from feeding in there correctly. It could be the feed tires or the belt as well in the document feeder.
It should be looked at by a technician in your area in case there are some parts that need to be replaced.
Jun 26, 2008 | Muratec F360 Plain Paper Laser Fax
thank u
May 26, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Scanning
Our problem is not solved. It was suggested the feeder needed cleaning or wasn't working. The feeder works as we make copies of documents. If one is scanning can you feed the document or can you only scan one page at a time by placing it on the window?
Feb 13, 2008 | Brother Office Equipment & Supplies
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Canon imageCLASS D1150 All-In-One Laser Printer Logo
54 people viewed this question
old marine
old marine
