Question about Xerox Phaser 3500/DN Laser Printer
Detect trays - Xerox Phaser 3500/DN Laser Printer
Xerox workcentre c2128 When i put paper in bypass tray, sensor dosnot detect this paper
You must manually define the papersize and orientaion of bypass tray at the printer console or printer driver.
Then print bypass tray (e.g. Tray6 on our Xerox).
Apr 13, 2014 | Canon Computers & Internet
Tip
CANON iR2016/2020 ERROR CODES
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
on Aug 03, 2010 | Office Equipment & Supplies
Does not detect tray
Look inside the machine, down the back of the paper tray, can you see any sensors that could detect if the tray has been installed.
Has there been any external damage to your paper tray, does the paper lift when you turn the paper lift gear by hand.
Try those points first.
Good Luck.
Jan 16, 2013 | Xerox Corporation COLORQUBE INK MAGN...
Where can i get the codes canon ir 2016 series.
Hi, here you go:
E540
E542
E744
0002
0003
0004
Jul 16, 2010 | Canon Office Equipment & Supplies
I want to find out what a report suspended error 0008 is and how i can get rid of it. Canon photocopier 2018i
ARE YOU SURE THAT IS E008?
hERE ARE THE ERROR CODES FOR 2018
E196 0001 Error on writing and readout ROM of image processor PCB (main ROM).
0002 Error on writing and readout ROM of image processor PCB (option ROM).
E261 0000 Zero-cross signal error
E540
E542
E730 0000 Inside error of the image processor PCB (PDL system error)
E744
0002
0003
0004
Sep 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Download standby error
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation error E019 0001 Waste toner full detection 0002 Waster toner full detection sensor failure E052 0000 Duplex unit connection error E100 0000 BD cycle out of range E197 0000 Erroneous communication with printer engine E500 0001 Finisher communication error E520 0000 Offset error E531 0000 Stapling error E540 0001 Paper surface not detected (standard tray) 0002 Not moved within the specified time (standard tray) 0003 Sensor not reached within 3 seconds (standard tray) 0005 Encoder clock failure (standard tray) E542 0001 Paper surface not detected (optional tray) 0002 Not moved within the specified time (optional tray) 0003 Sensor not reached within 3 seconds (optional tray) 0005 Encoder clock failure (optional tray) E575 0000 Stack delivery error E584 0000 Shutter failure E716 0000 Erroneous communication with optional cassette E719 0000 Erroneous communication with card reader (serial communication) 0002 Erroneous communication with coin vender (serial communication) E733 0000 Erroneous communication between controller and printer E736 0000 CCU communication error E739 0000 Erroneous communication between controller and network board E744 0001 Language file/boot ROM/USB memory error 0002 0003 0004 E805 0000 Fan failure E808 0000 Fixing drive circuit failure
Apr 10, 2009 | Office Equipment & Supplies
Canon IR2018 E007
E007 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
you need to call a canon technician to sort it out
Mar 22, 2009 | Toshiba e-Studio162D Copier
System error E808
0002
0003
0004
Mar 22, 2009 | Canon CLC 1140 Copier
PAPER SIZE DETECTION ERROR
Are you tring to use a paper tray or the manual by pass tray?If you are tring to use a paper tray for more then one or more copiers, you are going to have to ask your service techs to change the setting of one of your paper trays to A4 in service mode. Or if that has been done, look behind the paper trays for a wade of paper blocking the size detect switchs behind the paper trays. Good Luck
Mar 03, 2008 | Canon CLC 1120 Color Copier
Canon iR5000 Tray 3 problem
look behind the tray and see if there is paper stuck behind the tray. Good luck
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
Xerox Phaser 3500/DN Laser Printer Logo
11 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
