Question about Bose Lifestyle 28 System
No sound from any of my speakers
I just moved and took the system apart. it worked fine prior to the move now it just does not make sound. everything turns on but no sound. I use a sound cable from the system to my tv's headphone port now it makes no sound what so ever. I tried the dvd player also and no sound. Help please.
Please off your dvd player and on it again and also check the input cables
Posted on May 22, 2009
I have the Z313 system. The right speaker works only intermittently. I took it apart (the right speaker only) and it looks okay inside. What else can I do?
Have your tried swapping the cables left-right to see if the problem moves ? If the problem moves you narrow down the problem to bad output to speaker or bad cable.
After that I'm out of ideas.
Sep 16, 2017 | The Audio Players & Recorders
NordicTrack C900 Pro Won't turn on
Double check:
Chances are that "$%#T Happens" is not your problem. And that if it worked prior to "dis-assembly, it should work after re-assembly". The common denominator is you took it apart & put it back together. So.. something was missed. A wire not connected, a switch not flipped, a wire in the wrong spot, the safety key not in the slot, etc, etc.
Good Luck
Mar 06, 2015 | NordicTrack Exercise & Fitness
Is there a replacement amp for my jbl SCS180.6S subwoofer? I tested the speaker and it's fine. I also tested the output from the stereo and it is also fine. When the sub is turned on, there is a b
No you can't! I should contact JBL for the location of the part. Transformers are safety parts and should only be replaced by the same part or those approved for use by the maker of the unit.
Dec 20, 2012 | JBL Audio Players & Recorders
I have a rockford fosgate ounch 325.1 (2004). I recently helped my parents move and took the sub and its sealed enclosure out of my 1994 Ford Explorer. The sub and amp worked until the move. After I...
it sounds like you have a short someplace. also, if you have a multimeter, check the voltage coming out of the speaker terminals of the amplifier. if the voltage is higher than 4 or 5 volts, the amp is probably bad.
Jan 10, 2011 | Car Audio & Video
No sound comes out of the speakers. They previously worked fine prior to moving
If you have a soundblaster or onboard sound card, be sure that the cord coming from the speakers to the computer is plugged into the green inlet in the back, not the black one. If you plugged into the black inlet there will be no sound from the speakers.
Sep 24, 2010 | Boston Acoustics BA745 Computer Speakers
No sound out of left speaker
To fix this I took mine apart. But I suspect it was the red and white speaker outputs. I unscrewed the screws and moved the red and white speaker outputs around and then put the thing back together. It now works again.
Aug 02, 2009 | Boston Acoustics MicroMedia Computer...
LG VX8700 - No sound coming from speaker
Sounds just like the problem I had. I took the phone apart and removed the internal speaker. Tried the contacts with another speaker from another phone...and it worked.This leads me to believe that the internal speaker has failed. I am now on the hunt to get a replacement speaker.
Jul 12, 2009 | Lands Phones
My computer sound system
Most likely the sub has the crossover in it, most likely the 2 input cables from whatever device you want to play through the system will plug into the sub then the 2 speaker cables will come out of the sub and go to the speakers, just be sure to have everything connected into and out of the sub and make sure the power cords for the speakers and sub are plugged in, I am assuming this is a self powered system wich means the amplifiers are built into the speakers and sub.
Aug 07, 2008 | Yamaha 5.1-Ch. Surround Sound Home Theater...
No sound from a sony stereo receiver.
Hi there
Have you checked that the speaker on/off switches have not been bumped also. They are often at the left hand end of the amp next to the power switch and easy to turn on. A Tape monitor switch engaged will also give you those symptoms. Check them out and get back to me here if you cant find the problem
regards
Graeme
Apr 06, 2008 | Audio Players & Recorders
No Sound
carefully plug back the minijack for the speaker at the out or spk,
normally the sound card has three ports 1. for MIC 2. LINE IN 3.OUT (SPK) - SPEAKER.
carefully plug the minijack for the speaker into the third one - OUT (SPK) - SPEAKER.
in pluging it in, first put on a media clip on the windows media player and carefully plug in the minijack for the speaker and surely you will hear sound.
UZOWUANYA
e-mail: uzowuanya@yahoo.ca
Feb 11, 2008 | Dell Dimension 3000 PC Desktop
Bose Lifestyle 28 System Logo
146 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
