Question about Canon Sx230 IS Digital Camera
Canon PowerShot SX230 HS lens cover not closing
One half of the lens cover on my Canon PowerShot SX230 HS is not closing when power down the camera.
SOURCE: Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
Posted on Apr 22, 2008
darntoothysa
  • 489 Answers
SOURCE: lens error restart camera but
Hi
Your lens is defective needs to be cleaned, repaired or replaced. If you got sand in the gears it will definitely jam up the lens! Sometimes you can tear down the lens and clean out the sand, and if none of the gears are damaged the lens will then work properly again.
There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know this because I OWN ONE that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help! Good luck from
Darntoothysam com
Thomas
Posted on Oct 10, 2008
t00nz
  • 4738 Answers
SOURCE: Lens error, restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jun 28, 2009
  • 102366 Answers
SOURCE: lens error, restart camera for canon power shot SX120 IS
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
Posted on Feb 14, 2010
CanonAssist
  • 5 Answers
SOURCE: lens error, restart camera canon powershot
The best thing to do is to first try restarting the camera. Do not push or pull on the lens as this will often cause other issues. Do not blow air in the lens as this generally moves any dirt or dust to the back and it sits on your imaging sensor, you'll end up with poor photos after that. The best thing to do is to have it serviced so it is fixed correctly and working the way it should be. The site that is great for the Powershot Models is: www.CamerasAndParts.com They only specialize in these Powershots and they have your exact lens error problem right on the site. Try them for help. They tend to be the best deal plus they're service is wonderful. You'll pay $89 for the repair, all of the service for that model and the return shipping back to you included with them. They'd be the place for help with this one, best of luck.
Posted on Jun 27, 2010
How to reset the lens cover "leaves" on a canon powershot elph 330 HS camera. I took the cover off to remove a dent and the leaves went flying. :(
Take all the bits you can find to your local service centre, and be prepared for a bill greater than the worth of the camera.
Oct 26, 2017 | Canon Cameras
My Canon PowerShot SX230 HS cuts off after 10-14 seconds of recording. A yellow exclamation mark appears and shuts the video off. A green light flashes and says the word busy at the bottom of the screen....
There may be other causes for your experience but I am thinking of two and these are:
  1. The memory card - video recording is best achieved with a card of Class 4 or higher. Anything less will pose problems.
  2. Settings on camera auto-timeout - check to make sure the auto-time out is set to default.
Aug 20, 2013 | Canon PowerShot SX230 HS 12.1 MP CMOS...
Can I fix a broken flash on the powershot sx230 HS?
Doubtful. It sounds like it's physically damaged and will need to go in for repairs. There could be an issue with wiring broken or circuit board damage.
Oct 09, 2012 | Canon PowerShot SX230 HS 12.1 MP CMOS...
Any advice on a sticking lens cover on the canon G7
This blog post outlines repair procedures for stuck lens covers. Recommend trying reader "Jeff's" fix first shown in the comments section.
Jan 20, 2010 | Canon PowerShot G7 Digital Camera
My lense cover is stuck in a half-way position (Canon Power Shot A530).
Jun 03, 2009 | Canon PowerShot A530 Digital Camera
Canon PowerShot A720IS Lens Cover Won't Close
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. The A720 is more complex, but the base procedures are similar:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 28, 2009 | Canon PowerShot A720 IS Digital Camera
Lens cover will not close
YES, BUT THAT IS A JOB THAT NEEDS TO BE DONE PROFESSIONALLY, DUE TO THE ALIGNMENT OF THE LENSES AND THE POWER DRIVE FEATURES. IF YOU GOOGLE CANON POWERSHOT A620 REPAIR SERVICE, YOU SHOULD BE ABLE TO GET A PRICE QUOTE BEFORE YOU SEND THE CAMERA IN FOR REPAIR. IS IT JUST THE COVER THAT NEEDS REPLACED OR THE LENS? THE COVER MIGHT JUST NEED TO BE CLEANED GOOD WITH AIR TO START WORKING AGAIN? WORTH A TRY. IF I CAN HELP MORE, REPLY TO:
ARCLIGHT1217
Sep 15, 2008 | Canon PowerShot A620 Digital Camera
Canon Sx230 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
