Question about Coffee Makers & Espresso Machines
Keurig lid won t close - Coffee Makers & Espresso Machines
Keurig troubleshooting
First open and close the lid again to ensure the brewer was prepared to brew BEFORE you close the lid on a kcup. Failing that, you could try unplugging the brewer for a few seconds, and trying again once the brewer has indicated it is ready to brew.
Sep 08, 2014 | Keurig Coffee Makers & Espresso Machines
Keurig rivo not puncturing
Just push the cup firmly down onto the lower needle before closing the "clamshell" and puncturing the lid of the K-cup also. Read the attached link, other people have this problem.
2nd link explains problem very well.
Preventative Measures How to Keep Your Keurig Brewing Cup Barista
Fix your Keurig imsolidstate
Apr 17, 2014 | Coffee Makers & Espresso Machines
My Keurig is stuck. The top of the handle won't go in :( it won't close. Stuck open.
Remove the Kcup basket and clean. Rest and strat over. Pull down and reset handle.
Jan 21, 2012 | Keurig Elite B40 Coffee Maker
Keurig b30 turn on here motor, no water comes into cup!!!! help
It takes about 3 minutes to brew. You cannot use a clear coffee mug (scensors won't detect it)
You should be able to turn it on, Then place k-cup in holder, Then close lid and water reservoir lid will pop up and you add desired amount of water. Then push lid down, place mug under spout and the blue light will light up and you push taht. Within 3 minutes you should have some coffee
Apr 08, 2010 | Keurig B100 Coffee Maker
Made a cup of coffee this morning and at first only the small cup was lit up to be selected. I chose the large cup anyway and it made the coffee. When it was done I opened the lid to remove the k cup and...
Hello. Definitely call keurig at
1-866-901-BREW (2739) Representatives are available 7:00 am to 12:00 midnight EST, 7 days a week
This is unacceptable and should be fully covered under warranty. Joe
Mar 05, 2010 | Keurig B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
801 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
