Question about Hoover Washing Machines
Hoover washing machine model vhd 842 80.door security light keeps flashing,not taking in any water have replaced the solenoid valve
dazmaraz
  • 67 Answers
SOURCE: doorlock light keeps flashing.
poss the interlock or the module has gone I have found that the neutral suppy on the board to the interlock can breakdown if the module has gone call an expert has these modules when new need to be configured to your machine as 1 module can serve about 10 models
Posted on Jun 25, 2007
  • 77 Answers
SOURCE: washing machine
-the conditioner compartment may be blocked
- the cable with spring that change course of the water may be out,
Posted on May 08, 2009
rylee_smith
  • 8619 Answers
SOURCE: Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 18, 2010
  • 155 Answers
SOURCE: My hoover washer dryer VHD is showing a fault E11
It means there is a problem with the dryer board on it.You can try removing
the lid and just check the dryer control board on it.Make sure the
connections are ok and that none of the wires are broken.Then if the wires are ok the dryer control board will need to be replaced.
Posted on Apr 10, 2010
SOURCE: After a power cut my washer wont work the door
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Posted on Apr 29, 2011
I have a hoover vhd 9163zd with error code E05,what component does it refer to being at fault,where is the component located
Error Code 05 is a NTC fault, either open circuit or shorted.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "E05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component. It could be the sensor or the temperature control module (NTC module).
Good luck.
Apr 20, 2015 | Hoover Washing Machines
I have a black hoover VHD 844 DB washing machine and recently after a wash has finished and ive the clothes removed water begins to very slowy fill the drum again. The water isnt smelly but looks dirty....
Your water valve is not closing all they way and either needs to be replaced or cleaned. Even though the video below is on a different washer, it gives you an idea on what is required to be done.
Nov 22, 2017 | Washing Machines
Water not turning off after 1st cycle. We use cold water only. I've been told it could be the solenoid valve.
Yes it does sound like the solenoid valve.Sometimes if you take the valve apart and clean it, it works. If not, then you will need to replace the valve. Hope you find this helpful.
Jun 14, 2011 | Hoover Washing Machines
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Apr 24, 2011 | Hoover Washing Machines
VHD 814 Hoover Vision HD wash stops and timer saver light flashes. Does not wash properly and have to select spin manually. Any answers?
this happens with mine too....
Any solution would be very welcome. The machine seems to have a mind of it's own.
Dec 21, 2010 | Hoover H160E Front Load Washer
Hoover visionHD vhd 842-80 will not complete its cycle (does not spin) lights flashing are 1200 &time saver button
Mine done the exact same thing and it was the bushes that went not the pump, so you can change them your self if you can
Nov 07, 2010 | Hoover Washing Machines
My hoover hpe236. The lights flash intermittently
Hello
Maybe the wire to the light has a loose connection or your bulb may need to be replaced.
ilona
Aug 02, 2017 | Washing Machines
Problem with Hoover 200M
Hi All
The solution is a faulty solenoid valve, either the hot or cold valve depending what temperature you are using.
Replacing the valve is easy turnoff machine unscrew hose, remove 3 srcews to lift control cover, slide out locking tab, unclip wires the replace valve which cost about 30-$40
Tobor
Aug 22, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
