Question about Vulcan Ovens
Broken thermostat on vulcan convection oven
Thermostat seems to be sticking. Works sometimes doesn't other times.
Buffalo12980
  • 625 Answers
SOURCE: SMEG SA708X Oven Heater problem
thermostat must be getting a blast of cold air from the door being opened.
Posted on Sep 06, 2007
SOURCE: OVEN will not heat
After reading the above, here is how I fixed my KEBS177DSS9
I pulled out the wall oven from the cabnet. Took off the back tin panel about 10 tin screws. Follow the wire from both heating elements. They are both connected to a thermo fuse. When using the self clean feature this fuse protects the oven from over heating and starting a fire. I put a jumper wire from the hot lead on the left and connected it to the 2 leads on the right side. I turned the power back on and turn the oven on to bake at 350 degrees. Yep It worked like a charm. I bypassed the thermal fuse and used the oven, until the new thermal fuse was ordered. If you have any questions about this fix email me at jodunn5555@aol.com Good luck
Posted on Dec 24, 2007
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Posted on Jul 17, 2009
arachnid
  • 11 Answers
SOURCE: thermostat has broken on my Necht Oven
Replace it as it is callibrated and cannot be repaired
Posted on Sep 09, 2009
  • 77 Answers
SOURCE: Oven not working, is it the thermostat or element
This will almost certainly be the element and is fairly simple to replace.
Posted on Nov 28, 2009
Replace thermostat on kenmore elite
Possibly none of these videos are exactly like your oven but it should give you enough information to get the job done.
Note that some of the videos are not for ovens.
Replace thermostat on kenmore elite oven YouTube
KENMORE ELITE Walloven Parts Model 79048033800
Oct 16, 2014 | Kenmore Elite 30 In. Electric Self-clean...
I have an hygena classic built in oven. The turbo cooking option heats up slightly and the fan works but doesn't get to temperature. The grill and convection oven work fine. Any ideas. The oven is about...
The problem is usually down to the thermostat - sometimes it can be moved and end up touching the grill and burning out - other than that they just wear out after time with the heat.
Have a look here for a spare - its easy to replace if your husband is half competent with fixing things.http://www.espares.co.uk
May 11, 2014 | Ovens
I self-cleaned the convection oven on my sc302tw, and now it does not heat on any settings, convection, bake or broil. It is 14 years old.
Looks like the sensor has tripped... on my Bosch oven, I opened the back. Connected to the thermostat is a switch with a little button which pops out to prevent the oven from overheating... push in the button to reset it and it should work
Nov 06, 2013 | Thermador Ovens
Pilot light issue
you cannot light the pilot on that oven manually. that oven is eletronic ignition. take off the panel under the doors, turn on the oven, and turn the thermostat to 350.
if you see sparking on both the right and left burners, you and it doesnt light, you need to see if the gas solenoid on the right side of the burner is getting power. if it is and nothing lit relace it.
if it is not, replace the ignition board
Jun 30, 2013 | Ovens
F8 heat low it goes up to 494 and stops there
It generally is the IR Element that has gone bad. Look for burned wiring where the IR Element enters the oven cavity. Check for continuity through the IR Element.
1. Check that the blower motor is moving air.
o Blower motor is not moving air: Check blower motor assembly
and verify motor is stalled. Unplug oven and correct obstruction or
replace motor. (For access to motor shaft, remove top panel.)
o Blower motor is moving air: Verify high-limit thermostat is
not tripped. See the high-limit thermostat information below.
High-Limit Thermostat:
o Thermostat tripped: Reset and determine why the thermostat
tripped (See Figure 38, Item 114). Look for excess build up of
grease inside the oven or any other source for a fire.
o Thermostat is not tripped: Check main convection heater.
1. Convection heater is defective: Unplug oven and replace the
convection heater and verify the K4 SSR (Figure 37) is not
shorted across output.
2. Convection heater OK: Check the K4 SSR.
o K4 defective: Unplug oven and replace.
o K4 OK: Unplug oven and verify all wiring. Verify P1 voltage on
I/O board is 5.0VDC (+/- 0.02) -
Aug 28, 2010 | TurboChef TORNADO Electric Oven
Vulcan convection oven model SG4d-1 will not ignite burners
Gas does not ignite. No spark. No Ignition light is not ON.
1. Shorted electrode on igniter/flame sense.
2. Igniter cable (high voltage) OPEN.
3. Heat relay malfunction.
4. Centrifugal switch in blower motor inoperative.
5. Transformer inoperative.
6. High limit thermostat open.
7. Interconnecting wiring malfunction.
8. Ignition module malfunction.
Sparks but gas does not ignite.
1. Gas solenoid valve off or inoperative.
2. Manual gas valve closed.
3. Gas supply OFF or insufficient gas pressure.
4. Inerconnecting wiring malfunction.
5. Igniton module malfunction.
Feb 23, 2010 | Vulcan Convection Oven - VC44EC-208-1
We have gas operated vulcans that are not baking evenly. And browning is very uneven
They need to have the thermostat calibrated. Go to Vulacans web and locate the calibration proceedure service manual.
Aug 06, 2009 | Vulcan Convection Oven - VC44EC-208-3
Ovens Logo
Top Vulcan Ovens Experts
John Tripp
John Tripp
Treefrog15
Treefrog15
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
