Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Defy washing machine frontloader daw 370
The spin & drain cycle gets stuck on 8 min then it just keeps on spinning for ever
  • 1073 Answers
SOURCE: washing machine not draining and spinning
check the lid switch
Posted on May 01, 2008
docjohn174
  • 943 Answers
SOURCE: Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Posted on Sep 11, 2008
jonniewalker
  • 1029 Answers
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Posted on Sep 21, 2008
  • 36 Answers
SOURCE: does not pump water out or spin after first wash
Dear Customer
Please perform the following
The first thing to check is the lid switch. Open the lid and you'll see a recessed spot that a tab on the lid fits into. Put a screwdriver into the spot, press down and see if you hear a click. If you don't, the switch is bad. That's if you're lucky.
It could also be something as serious as the transmission. Try this: In the search box at the top of the page, type in repair (brand, like ur Whirlpool or anyother etc) washer. A list of sites will come up with a bunch of troubleshooting tips and repair instructions. I used this to fix my washer a couple of weeks ago. Good luck.
Please rate this,Thank u
Posted on Dec 17, 2008
  • 942 Answers
SOURCE: washing machine drains, wont spin, making clicking
If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jan 30, 2010
My Defy DAW 365 washing machine goes through the whole washing cycle but it just won't spin. It does drain between the washing cycles.
If the poly-vee drive belt in your washing machine has snapped, the motor will no longer be able to turn the drum. The drive belt is an important component of any washing machine as it drives the motion of the unit where the clothes are washed and spun. If your washing machine is making a loud noise or no longer spins, then the belt is probably worn or damaged.
Oct 23, 2015 | Washing Machines
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
Washer wont drain lg tromm frontloading washer
You need to isolate the drain pump and check the voltage at the time of the drain cycle. If no voltage is present then you need to check on the control board as it can be a failure of the drive.
If voltage is present but there is no drain action then the valve pump is stuck, choked or faulty.
remove and check: click on : Drain.
Feb 27, 2013 | LG WM2016C
Front loader machine stuck before spin cycle
This is an issue with the pressure switch, it is having issues detecting the water level.
Mar 11, 2012 | LG Washing Machines
GE frontload washer doesn't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
My washer started just find, then have way through the wash it stoped dispensing water and will not drain. Tried spin cycle only, and nothing. Tried unpluging, and still same problem Tried restarting...
all frontloaders have to start the drain pump before any cycle will start ... if there is something stuck in drain pump or hose between bottom of wash tub to pump washer will not spin... check filter pump assymbley and drain pump
Jan 24, 2011 | Frigidaire Washing Machines
Our defy automaid 600 daw 322, will wash, but will not spin or rinse
My Defy Automaid 600 spin and drain without washing but only drain and do not spin with washing in (i have put only 1 t-shirt in - and still don't spin)
Jan 23, 2011 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
135 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
