Question about JAKKS Pacific Big Buck Hunter Pro TV Plug n Play Game 10204214
Connection to tv instructions - JAKKS Pacific Big Buck Hunter Pro TV Plug n Play Game 10204214
I can't get the right tv to game connection for plug and play golden tee live
Hi, i dont have this game but I recommend searching up instructions on google. The company who make this game would probably have instructions on their websites. Hope this helps
Dec 24, 2012 | Radica Golden Tee Golf Plug And Play Home...
I was given a technika hd ready dvbt dvd built in freeview with no instructions.I need instructions how to tune in freeview.It had previously had the freeview tuned in but now the channels are not...
hi,
First of you have to check the Atenna connection in the rare of your tv. Check for any loose contact on the connection of the wire to the pin. may be its the cause for showing signal as 0%. you can confirm the same by connecting the tv at the place where you doughters tv is connected. If there you get the picture then there is some thing wrong with the atenna connection.
If want information how to tune your tv then need information like BRAND and MODEL NUMBER of you TV.
ok
Aug 05, 2011 | Televison & Video
I am able to stream netflix, however, I was told I should be able to access everything else from my PC on the TV, as well. Therefore use my TV as a laptop. How do I do that??
If your Television has netflix installed on it, you will need to connect the television to the internet and follow the on screen instructions to enter your information.
If it doesn't, you will need a device that has netflix on it that can connect to the computer (an xbox, PS3, Wii, or compatible player) that can connect to the internet. Again, connect the device, choose netflix, and follow the onscreen instructions.
I can provide more details about these on screen instructions if I know what device you are using.
As a third option, you can connect your laptop to the TV with any video or audio cord. HDMI is a favorite if your computer has an HDMI output port and your TV has an HDMI input.
Jul 21, 2011 | Computers & Internet
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
I cant make the freeview box work without the operating instructions
OK - please follow these instructions carefully to setup the Freeview box. If you get stuck at any point in the instructions - or anything I've said doesn't make sense or match what you can see - just post another message here and I'll deal with each problem as it arises.
1. Switch the TV and Freeview box to STANDBY. There should be a red light on the Freeview box;
2. Connect the aerial cable to the freeview box. Make sure you are connecting this to the correct socket. This should be labelled "RF IN", "IN" or "Aerial/Antenna". If you have connected to a socket marked "RF/TV OUT" or "TO TV" or something similar, it wont work;
3. Connect the SCART cable to Freeview box and the back of the TV;
4. Switch the TV on;
5. Switch the Freeview box on - you should get a green light on the front of the box;
Most TVs will automatically switch to the external input when a SCART device is switched on while the TV is already on. This is why you should switch the TV on first.
At this point you should be able to see the installation / setup screen for the Freeview box displayed on your TV. If you cannot see this:
A. Press the INPUT button once on your SAMSUNG remote control once. This is the button in the top-right corner of your remote control.
B. If you still cannot see the installation / setup screen, press the MENU or SETUP button on the remote control supplied with the Freeview box.
The instructions from this point forward will be different if you had to press the MENU / SETUP button on the Freeview remote before anything appeared on the TV screen. If this Freeview box has been used before the installation screen will not appear, but you will get at on-screen menu after pressing the MENU / SETUP button. If this happens, please let me know and I will provide alternative instructions for setup.
Assuming you have been able to access the installation screen, it should be easy enough to follow the instructions on screen from this point. Use the UP / DOWN / LEFT / RIGHT arrow keys on the Freeview remote to highlight the relevant options and then press OK / SELECT to choose that option.
I don't want to make this too complicated by providing alternative instructions for every possible scenario. Please run through the instructions above and make sure you are getting an installation screen or "menu/list" displayed on the TV. If you need further instructions from there, I will provide them in another message.
Good luck - I'll await your reply.
Regards,
BElectric
Feb 09, 2011 | Televison & Video
TRYING TO INSTALL DIGITAL SET-TOP BOX WITH DVD AND TV
Hi ccraigo
To answer your question;
Your motorola will connect directly(not through the dvd) to the tv set into one of the input ,(preferably using hdmi or component cables for hd) and the dvd will use a different input,
All you have to do then is switch between which one you want to watch.
Hope this help Cheers
Apr 20, 2010 | Pioneer Televison & Video
RC65 won't connect to TV or Blue Ray
Instructions for Code Searching with your RC65 are here.
If you'd like a digital manual for your RC65, click here.
I hope that helps.
Dec 19, 2009 | Directv RC32RFK Remote Control
JAKKS Pacific Big Buck Hunter Pro TV Plug n Play Game 10204214 Logo
52 people viewed this question
Top JAKKS Pacific Toys Experts
ray gallant
Are you a JAKKS Pacific Toy Expert? Answer questions, earn points and help others
