Defy washing machine gets stuck on 8 min when busy with spin and drain cycle
  • 1073 Answers
SOURCE: washing machine not draining and spinning
check the lid switch
Posted on May 01, 2008
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Posted on Jun 04, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
  • 662 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
Posted on Jun 17, 2010
My Defy DAW 365 washing machine goes through the whole washing cycle but it just won't spin. It does drain between the washing cycles.
If the poly-vee drive belt in your washing machine has snapped, the motor will no longer be able to turn the drum. The drive belt is an important component of any washing machine as it drives the motion of the unit where the clothes are washed and spun. If your washing machine is making a loud noise or no longer spins, then the belt is probably worn or damaged.
Oct 23, 2015 | Washing Machines
My washing machine won't spin when in a wash cycle but will spin on a spin cycle
???? ITS NOT SUPPOSE TO SPIN WHILE WASHING ? DO U MEAN ITS NOT AGITATING? THEN LOOK AT UR PRESSURE SWITCH AND UR CAM DOGS. MOTOR COUPLER OR BELT. NEXT UR CLUTCH BRAKE ASSEMBLY MAY BE BAD
Jun 09, 2015 | Hotpoint WF430 Front Load Washer
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
Defy dishwasher leaks water only at the end after spin cycle
please confirm if you are referring to a dishwasher or washing machine. Usually the spin cycle applies to washing machine. Check where the water is leaking from. Most likely the drain pump hose is cracked. Need the model number of washing machine to make further suggestions.
Dec 29, 2012 | Dishwashers
Front loader machine stuck before spin cycle
This is an issue with the pressure switch, it is having issues detecting the water level.
Mar 11, 2012 | LG Washing Machines
Defy Automaid Washing Machine Model DAW265 - WONT SPIN Hi there: The machine runs perfectly through all cycles - fills up properly - drains perfectly - but will not spin at all [sounds like it is...
Possible fault of the program controller unit, the program output to the motor when the cycle is in the SPIN mode must be checked.
Make sure that the output is available, check using a multimeter to confirm. If absent then check the program module to confirm.
Jun 13, 2011 | Washing Machines
Our defy automaid 600 daw 322, will wash, but will not spin or rinse
My Defy Automaid 600 spin and drain without washing but only drain and do not spin with washing in (i have put only 1 t-shirt in - and still don't spin)
Jan 23, 2011 | Washing Machines
Won't spin cycle
when sitting for the last spin it may be out of balance,when you have no cloyhes in it,put 1cup of HE clorox bleach and let it sit in tub over nite,then run on heavy duty wash hot water cycle.(no clothes) this should open up drain pump.this may take several trys.
Jul 31, 2010 | Bosch Washing Machines
Washing Machines Logo
Top Washing Machines Experts
