Question about Dryers
Zanussi TD 524 drum will not rotate - Dryers
SOURCE: Zanussi TD 4112 W Not warming up
I've taken the back cover offf the dryer and found a burnt connection to the heating element. Will try and repair.
Posted on Oct 19, 2008
  • 1244 Answers
SOURCE: how do i replace a drum belt to tumble dryer
remove lid then take screws out from inside front cover/lid and slide drum out
Posted on Jan 13, 2010
Ranglo
  • 1194 Answers
SOURCE: ai need a new motor for zanussi dryer model no td
You'll need to contact Zanussi Service center in case you want to buy new motor, Visit this Link and put your postcode to locate nearby service center.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Posted on Jun 21, 2010
barkencoa
  • 3463 Answers
SOURCE: My 20 year old Zanussi
More than likely is belt, remove the top cover, and you should see if it is the belt.
If you are in the u/k, then go to---
WWW.SERVICEFORCE.CO.UK
You should be able to arrange for an engineer to visit, or look in yellow pages for local repair company.
Posted on Jan 26, 2011
barkedat24
SOURCE: Zanussi TD 4112 W....drier turns on and the heat comes put but the drum doesn't turn?
belt is broken drive pullt is off tension pully is broke
Posted on Nov 10, 2012
Zanussi turbodry wdt 1075 washing machine fills & drains but does not perform wash cycles or spin cycles drum does not rotate
Quite probably the motor brushes. Disconnect from mains. Tilt machine backwards as far as possible. On motor, disconnect wires to brushes. With a multimeter, check continuity between brush and any segment if the commutator. If open circuit, replacing the brushes should do the trick. Also visually examine the commutator for damage
Aug 17, 2014 | Zanussi Washing Machines
Where is the heater element in Zanussi td 421
They are under the drum in a metal box that is connected to a heater hose and wires. Make sure you unplug it before you work on it. Note the location of the wires that connect to it and also there is a thermal fuse and thermostat that are hooked to the box. Check those too.
Aug 10, 2012 | Zanussi TD4212W Electric Dryer
My 20 year old Zanussi dryer model TD 260 has stopped rotating, but the heat is on. Does this mean the belt has gone and where do I get an engineer to fix this.
Jan 26, 2011 | Zanussi Dryers
We have a Zanussi model ZWF1621W washing machine and a piece of bra bone(wire) has gone through the holes in the drum and is stuck and rotating with the drum against the drum outer body how do we get it...
DONT RELEASE SEAL. Tilt machine and remove sump hose get someone to rotate drum in hope you can catch hold of wire. be careful of fingers on drum as they are like cheese grater. good luck this is best way and a little patience will do the job
Feb 12, 2010 | Zanussi ZWF1630 Front Load Washer
How do i replace a drum belt to tumble dryer Zanussi TD 4212W
Jan 13, 2010 | Electrolux Dryers
TD 4112W Dryer does not auto reverse
my new dryer makes athumping sound when in use and it sounds like a pair tennis shoes are being dried
Feb 16, 2009 | Zanussi TD4112W Electric Dryer
Zanussi zwf 1020w drum not revolving
The drum will not rotate until the draining process is satisfied, there is either something in the pump or pump is broken
Oct 20, 2008 | Zanussi FJD1666W Front Load Washer
Oct 14, 2008 | Zanussi TD4112W Electric Dryer
ZANUSSI TD4212W drum does'nt turn, heat works any ideas?
with top off and machine in operation, try giving the drum a push by hand. if it starts to rotate and continues to rotate, then the fault is with the motor capacitor - cheap part
and of course, with the top off, check the belt is in position and not broken
Sep 09, 2008 | Zanussi Dryers
Dryers Logo
10 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
