Samsung remote proscan tv
Cannot get the remote that came with my samsung ht-f5500w entertainment system to work with my proscan 39" tv. I tried all 2 digit codes from 00 to 99
ANTHONYPAULB
  • 17 Answers
SOURCE: Samsung program codes for ht-q100 Remote
You can try any of these 006, 011, 014, 015, 019, 027, 036, 037, 077
Hope this helps..
Posted on Nov 30, 2007
SOURCE: COMCAST REMOTE AND SAMSUNG TV
I was having the same issue with a Samsung 4053 40"
Comcrap had no clue.
Their phone rep suggested I come in and trade out the remote. That seemed unlikely if others are having the same experience. It is also unlikely a phone rep would have any answer other than what on the web page.
I used 5 digit code "10060" and it worked got the double flag from the remote like Comcast's documentation says. It turns TV on and off and works volume. So far so good.
The key to figuring it out was getting the double flash on the remote 4 digits didn't 5 did.
The moral of our story? Comcast has no clue what they push out the door. I guess that isn't a surprise to anyone.
Posted on Jan 13, 2008
SOURCE: Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
Posted on Feb 04, 2009
SOURCE: lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Posted on Mar 17, 2009
SOURCE: cant control tv with direct tv remote
I don't know what size TV you have but just installed Direct TV for parents and none of the codes worked after a LONG time my husband tried the Sears codes and got the last one he tried to work. He used 10056. It is a 47 inch LCD Proscan TV. If that doesn't work, you might want to try all of the Sears codes to see if one will work for you. Good Luck
Samsung HT F5500W The system worked without a problem. I painted the room so I had to disconnect everything. After connecting back rear speakers does not work and the link light on wireless box is...
with the main unit off. Press and hold the link button on the back of the rear wireless amp until it starts blinking fast. The take the remote and while pointing at the main unit, press 0-1-3-5 enter. Wireless link ready should show on the display. Turn on the main unit, and it should find the rear amp.
Jul 17, 2014 | Audio Players & Recorders
I would like to make my SAMSUNG HT-F5500W region free
There seems to be useful info here:
http://forum.videohelp.com/threads/342271-Samsung-HT-D6750w-Region-Free
Dec 07, 2013 | Samsung HT-F5500W 5.1-Channel 3D Blu-ray...
The remote for my samsung ht-tx72 doesn't work even though the tv and dvd reciever lights on the remote work. It doesn't turn on my home theater system. Do I need to reprogram it?
Possibly. Maybe it's malfunctioning.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 12, 2011 | Samsung HT-TX72 Theater System
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Mar 18, 2009 | Samsung HT-A100T Theater System
Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 17, 2008 | Samsung HT-Q100 System
Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Jul 25, 2008 | Zenith ZEN700 Remote Control
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
