Question about Canon PIXMA MP180 All-In-One InkJet Printer
Get error: check ink u059 col
Canon Pixma MP 180 gives and erro called: check ink u059 I have replaced both the cartridges please help
  • vivialidya
    vivialidya Jul 14, 2012
    tuku o sing anyar,,, means: just buy the cartridges for it.
For me, this meant that I put it an ink cartridge that wasn't compatible.
Posted on Jun 16, 2009
Refilled the ink cartridges and now get error message U059 check col ink. I've cleaned all the contact points, any thoughts on how to reset the printer to recognize the cartridge?
Refilled cartridges give a lot of trouble , I only use genuine. click start, devices and printers , right click the printer image, click trouble shooter follow instructions. Don't be supprised if the only fix is a new cartridge.
Jun 11, 2015 | Canon Pixma MX410 All-In-One Printer
Check Ink error U059
Canons definition of U059 is:
"The FINE Cartridge may not be installed properly, or the Cartridge may not be compatible with this machine. Open the Scanning Unit (Printer Cover) and install the appropriate FINE Cartridge. If the error is not resolved, the FINE Cartridge may be damaged. Contact your Canon Service representative."
In my experience this is normally due to dirty or damaged contacts on the cartridge. I would recommend wiping the contacts on the cartridge with a piece of kitchen tissue and trying again. if this doesn't help try simply replacing the cartridge.
If the error persists try cleaning the corresponding contacts inside the printer in case they have become dirty/oxidised.
Oct 17, 2012 | Canon PIXMA MX310 All-In-One Printer
My canon PIXMA MP450 all-in-on-printer is showing U059 the following ink cartridge cannot be recognized i tryed to put the old ink tank in but it said the same thing
Basically, there is no solution for your case. This happens especially for Canon product.(called e5 error) Once a cartridge is not recognizable, there is no way, you can use it.
The only way you can do is, replace with brand new one. This is typical Canon problem especially when you refill or re-use your cartridges.
You may see some solution from web such as reset the printer, do somthing to printer software... But non of these methods are working.. Even if there is one, it must be very difficult to do it for individual users.
However, as for a prevention, make sure unplug the power cords before insert or eject the cartridge from printer. In that way, you can at least reuse your cartridges for refill. Hope it helps.
Dec 13, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon printer pixma mx310 will print but will not make a copy. It gives message "col ink vol inknown"
> col ink vol in known
The amount of INK in the COLOUR cartridge is not KNOWN.
Replace the COLOUR ink-cartridge.
May 22, 2011 | Canon PIXMA MX310 All-In-One Printer
Hello.i have a canon mx 300.i have changed both ink carts[properly] and it reads"U059 check ink col".any suggestions?thanks...
check that the tape that coverd contacts has been fully removed and that there is no residue on either the cartridges or the receptacle the error points to the color cartridge, it has happened to me previously were a cartridge is bad out of the box and needs to be replaced.
Jun 20, 2010 | Office Equipment & Supplies
MP 170 check ink
U051,U052,U053,U059 all are signal or Error is mean CHECK CARTRIDGE
The Fine cartridge may not be install properly,or the cartridge may not be the compatible with this machine.Install and appropriate the fine cartridge.
Dec 03, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Impossible to use a Canon mp 180
Hi Lui,
this is a common problem when using refilled cartridges.
You can either go into Control Panel --> Printers and Faxes
Right click on the printer and select properties, then look for a maintenance or color section
There should be a setting to ignore the cartridge levels
If this fails look at the solutions here:
http://tricks-collections.com/2008/04/reset-printer-canon-mp140-mp160-mp180-mp210-mp220-mp460-mp470-mp500-mp510-mp530-mp600-mp610-mp800-mp820-mp810-mp830-mp960-mp970/
thanks, good luck HPC
Feb 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error Message V163
well col probably stands for color.....i would try unplugging your printer for 10 seconds then plugging it back in....that resets the printers memory. did you buy the right black ink cartridge? that might throw a error code.
Sep 22, 2008 | Canon PIXMA MX310 All-In-One Printer
Open Questions:
See all Canon PIXMA MP180 All-In-One InkJet Printer Questions
Canon PIXMA  MP180 All-In-One InkJet Printer Logo
4,408 people viewed this question
old marine
old marine
