Question about Miele 23 in. KM360G Gas Cooktop
No spark ignition - Miele 23 in. KM360G Gas Cooktop
Maytag/Jenn Air JGD8130ADS one burner will not ignite but all others will. solutions?
Turn off gas. Remove the cartridge and remove back cover. Clean the ignition spark area. Re-install the cartridge without the back cover. Try to ignite the spark. If the spark works. The spark wire is too close to the back cover. Use an electrical tape to insulate the wire from the back cover. Other swap the two spark to see if you have a faulty spark.
Jan 02, 2012 | Maytag JGD8130ADS 30 in. Gas Cooktop
2 of 5 burners do not start
The spark gap needs to have flow of gas across it for ignition to occur. The gas outlet holes at the point where the igniter sparks may be blocked, clean and inspect these for any blockages. Also check that the igniter spike is in the correct place. Careful evaluation of the position of the igniter in reference to the gas ring on the other rings may help you here. Good luck
Feb 02, 2008 | DCS CT-365 Gas Cooktop
Tip
Cooktop Range Stove spark ignition does not work
You go to light the burner on your cooktop and the spark does not work.
What can the problem be? In most cases the problem will be because the
spark ignition module has gone bad. This spark module is a piece of electronics that produces a harmless electric spark at 2-4 pulses per second. Because the spark is a ultra low amperage spark, it is not dangerous.
A typical spark ignition will look similar to this.
This box is usually in a metal box located somewhere under the cooktop of your stove or in the back panel of your stove. The easiest way to find this is to simply follow the electric wires that go from the spark ignition box to the spark tip located at each of the burners.
The spark is activated by a switch that is located behind each of the burner control knobs. When one of the switches is turned on, all of the burners spark at the same time. The spark switch will look something like this.
To troubleshoot the spark ignition you need to determine if the system is wired in series or parallel. If the system is a series system and one is not sparking, then none will spark.
Almost every time if the spark is not working, it is because of a bad switch. To isolate which switch it is, turn each switch till you find the one that does not activate the module to spark. You can confirm this by pulling the two wires off of the switch and touching them together. If you get spark you know that the switch is bad. If no spark happens then either then a wire is bad or the module is bad. If none of the switches cause the module to spark then it is a good assumption that the spark module is bad.
By checking through these procedures you will be able to tell whether your problems are caused by a bad switch, a bad wire, or a bad spark ignition module. You will discover almost every time that the switch behind the burner is the part that needs to be replaced.
on Aug 18, 2010 | Cooktops
How do I replace spark ignitor on GE JGP963SEF1SS gas cooktop?
If none of your burners are igniting, you need a new Spark Module. If only 1 or 2 of your burners are not igniting, you may need a Spark Igniter. Click on the pictures below for a larger image.
The Spark Module is number 318 in the following diagram (underneath the burners):
The Spark Igniter is number 154 in the following diagram:
Jun 02, 2011 | GE Cooktops
The igniter spark for all gas rings remains on permanently without pressing down the gas flow knobs. I can see nothing prompted this - I just came into the kitchen one morning to hear the igniter clicking...
This could be a problem with your spark module. its an electronic box either behind or under the cooktop. it sends the spark to the spark tip, which then ignites he gas. So in my opinion i would say it is your spark module.
Feb 02, 2011 | Smeg 23 in. SER34AX1 Gas Cooktop
3 of the 4 burners clicks and sparks when I try to
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jul 27, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Rear burner does not ignite
Spark units are replaceable
Jan 06, 2009 | Cooktops
Miele 23 in. KM360G Gas Cooktop Logo
479 people viewed this question
Top Miele Cooktops Experts
Dan Webster
Dan Webster
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
