S42sd yb06 dead
Won't switch on. no standby light. no fuses blown. help please
5 Suggested Answers
  • 8457 Answers
SOURCE: Dead TV
U know basic electronic's,and u know how to do soldering?Have soldering iron,tools and solders?The power supply board,the board that the power a/c power cord plug into it.That the power supply board have these parts call capacitors are dead.These capacitors alway bulges up on it top or puff on it top.Check all around the power supply board and it supporting boards.Replaced these dead leakage bulges up on it top or puff up on it top.Or tries websites like Shopjimmy.com,Ebay.com to buy and replaced the whole refurbish power supply board.
Posted on May 28, 2010
SOURCE: Hi,my LG 26LB75 LCD TV displays nothing at all,no standby
hey man,
i have th same problem. have you find any solution?
Today i will verify, if the problem isn't it in noise filter IF - N06AEW.
I will post a result. Please let me know about your solution.
thanx
mailto: daniberk@centrum.cz
Posted on Jul 16, 2010
SD Tech
  • 14553 Answers
SOURCE: My LG 32LD320 won't turn on. I have no standby light and have even tried changing the fuse. Help please!
If total dead best way is to follow the AC voltage from power cord inside the set to see where voltage is lost.
Also , were you having any problems having to turn set on several times to get it on?
Posted on Mar 21, 2012
spr1949
  • 1182 Answers
SOURCE: stand by light won't come on tv wont play checked switching adaptor
If looked for loose contacts in power outlet, RC Jack, cable and connectors, you have tried using different input devices, the TV might need service.
Posted on Aug 26, 2012
WHAT WOULD CAUSE A MODEL FPE3707HR AUDIOVOX TV TO BE DEAD
Hi David, If you you're not getting a standby by light, then it sounds like the main fuse on the power supply is blown.
May 23, 2014 | Panasonic Televison & Video
Where is the reset or fuse on the lc391eme tv
The fuse is located on switched mode power supply board. If the fuse has blown the set will be dead no standby led light on front of set also when you plug the set into a power outlet you should hear the relays clicking. if you don't hear the clicking then the fuse has blown or another part of the power supply has failed and will require service.
Apr 27, 2014 | Emerson LC391EM3 39 in. LCD HDTV
2007 dodge charger 5 7 hemi
Check for a blown brake light fuse if no fuses are blown check your brake light switch I believe one of the 2 will be defective and will solve your problem if this was helpful please leave good feedback
May 23, 2013 | Dodge Cars & Trucks
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
Mar 20, 2012 | LG 32LD320 32 HDTVReady LCD TV
It won't turn on
hi; try to check the power cord ,
if power cord has no problem it has standby light coming from the TV
when no light or dead set. there a fuse blown on the power supply section.
if there's standby light wont start , even if you press the power button , it has a power supply failure, maybe some capacitor ha bloated or change the value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician. thanks ,, hope this help.........
Sep 05, 2011 | Mitsubishi LT-55265 55 in. HDTV LCD TV
I HAVE PAYED $20 TO GET SOME HELP WITH MY DASH LIGHTS NOT WORKING. ALSO MY PARKING LIGHTS WON;T COME ON. ALSO MY FOG LIGHTS WON;T COME ON. I HAVE ASK YOU SEVERAL TIMES TO HELP ME. IT MAKES ME THINK. YOU...
Sorry about that, I must have missed your post or something. The park lights and the panel lights are usually on the same fuse and therefore on the same switch. The fog lamps are on a separate fuse and switch/circuit, although the is nothing to prevent either of the fuses going at the same time. Look at the fuses first, if they are blown replace them, but if they blow again some more investigation will be required. The parking lamps/panel lights are unlikely to have a relay, but the fog lights may.
The fuse must be in the main fuse box. The position and function of the fuses is normally marked on the inside of the fuse box cover and also in the owner's handbook. If you don't come right with these, work your way through the fuses looking for a blown one. To ease your search the fuses you are looking for should be around 15 to 20 amps.
Mar 06, 2011 | Jeep Grand Cherokee Cars & Trucks
HITACHI 37PD5200 E Plasma dead.
The fuse is either open or it will have continuity do you have any standby voltages
May 14, 2008 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
