Question about Sharp AR-405 Printer
Sharp ar 405 u2-11 error
Please advise how to clear this error
    Problem Solver:
  • 11 Answers
Content Counter check sum error (EEPROM)
Detail Checksum error in counter data area
Cause EEPROM defective
Control circuit hung up due to noise
Defective EEPROM access circuit on
PCU PWB
Check Check EEPROM for proper set-up
and To prevent the erasure of counter data
remedy and adjustment values, write down the
counter data and adjustment values by
simulation. (If there is a printer option,
execute SIM23-1 and note counter
data/adjustment values.)
Clear U2 trouble with SIM16.
Replace PCU PWB.
Posted on Oct 05, 2009
Sharp Ar-405 H4 error, when reset it goes right back to H$. What Part do I need to replace?
THE ERROR IS IN THE FUSING SECTION SO i WOULD LOOK THERE IF YOU HAVE RESET THE CODE EITHER THE LAMPS OR THE THERMISTORS ARE DEFUNCT SO THAT WOULD BE MY ADVISE TO START IF YOU TEAKE THE FUSER OUT GET AN ELECTRICAL TESTER AND CHECK THE LAMPS FOR A CONTINUITY BETWEEN THE CONNECTIONS IF THE THERMISTOR NEED CHECKING YOU CAN DO THIS ON RESISTANCE BY TURNING YOU TESTER TO THE OHMS SETTING AND CONNECT ACROSS TWO ENDS THEN PUT FINGER ON RESISTOR AND CHECK THE READING ALTERS . IF IT DOES THEY SHOULD BE FINE YOU CAN CHECK THE THERMO FUSE TOO.. GOOD LUCK a
Jun 30, 2009 | Sharp AR-M205 Copier
Sharp AR-405 showing error H3-01... how do I reset this error?
press the following in sequence
program / interrupt /clear /interrupt
press 14 and enter
restart and away you go.
let me know if it works
Jun 22, 2009 | Sharp AR-M205 Copier
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Sharp AR 5320 error h200
H4 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
916 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
