Washer won't start
Three lights are on the washer and it won't start
MakeupWizard
  • 39 Answers
SOURCE: washer won´t start
Hiya,
Machines not starting are often due to the water not getting through 1st check would be to make sure the hoses are connected correctly & that the water taps to the machine are switched on this is a common problem when an apliance has been moved for either cleaning or re-instalation after a move, if it is the taps not switched on the macine will start working again straight away if it's not the taps then it could be the pump.
Hope this helps
Posted on Apr 22, 2010
Macmarkus
  • 2605 Answers
SOURCE: bosch nexxt series 100 washer. washer willnot
Welcome to FixYa.
It sounds like a bad door latch/lock. It will require you to remove the front door seal spring to gain access to the part.
If this sounds like something you can repair I'll try and help in whatever manner I can or you may opt to call a pro.
Let me know how it goes and if you require further assistance. Thanks for choosing FixYa. Good luck
Regards,
Macmarkus :)
Posted on Feb 23, 2011
oldTech2332
  • 2341 Answers
SOURCE: my washer panel will light up and the load washer
To me that sounds like the problem may be within the door switch/lock, on the doorlock asm. is a little botton that sticks out of it,look and see if its their or perhaps its broken off. What that button does is tells the washer the door is closed so it can go ahead and lock it to start the cycle,its perhaps broken off sothe machine doesnt think the door is closed and thusly wont start.
GENE
Posted on Oct 06, 2011
soj_er_05
SOURCE: i have kenmore elite he5t washer and door lock light won't turn on to be abele to start the washer machine
answer of puk code
Posted on Jan 26, 2012
SOURCE: Ge Washer won't start, lights come on but won't stay on, what do I do?
Go online and search for brand and model number service manual. There are probably multiple things it could be, but the troubleshooting section should point you in the rite way.
Posted on May 30, 2012
Ge washer "lo" light when lid is closed. and won't start after it has run before
"LO" means the washer's lid is not closed
What is the model number?
Oct 13, 2012 | Maytag Washing Machines
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
May 30, 2012 | GE Washing Machines
I haven't used my washer in three years and now I
sounds like the door lock mechanism has failed. somewhat easy to replace if you're inclined to do so.
Mar 02, 2012 | Electrolux Washing Machines
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
