Question about Belling Kitchen Ranges
B90 oven cutting out
Good Afternoon, A belling db90 where the main oven keeps cutting out at high temperatures? any suggestions? Cheers
2 Suggested Answers
  • 2976 Answers
SOURCE: convert my belling DB90
You will have to change the orifice to accomodate lp gas.
Posted on May 08, 2009
Temperature when using frigidare oven, keeps getting hotter and does not cool down
Good Afternoon Andrea,
I see that you're having issues with your Frigidaire oven, and the heating element being red hot the entire time you were cooking no matter how much you turned the temperature down.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your oven, you will need to set the clock by entering in the time and pressing start. Preheat the oven, to whatever desired temperature, and if it is still running hotter than it should be, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire Ovens
Tip
Common faults with Belling DB90 Range
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling DB90 Electric Kitchen Range
Oven shuts off while baking and will not restart till oven cools off??? thanks mark
Good Afternoon Mark,
I see that you're having trouble with your Frigidaire range, model# PLCS389DC, shutting off in mid-baking, and will not restart until the oven has cooled. It sounds like it is either the temperature sensor, that is sensing a runaway oven temperature, or the control board itself that might need replacing. I suggest contacting you local authorized technician for further assistance. They will be able to determine what exactly is causing your oven to cut off in mid-baking.
-Best Regards-
WP
Apr 01, 2014 | Frigidaire PLCS389DC Dual Fuel (Electric...
Thermal cut out
Probably the internal temperature sensor, not a difficult job but if you attempt it yourself kill all power to oven.
Nov 19, 2013 | Belling Ovens
Convert my belling DB90
Feb 03, 2009 | Belling DB90 Electric Kitchen Range
Main ovens dont work
if the clock is not set the ovens wont work,they dont have to say the right time but they do have to have a time. to set the clock hold the hand button and the clock button(first two buttons),and then plus or minus to set the time
Dec 12, 2008 | Belling DB90 Electric Kitchen Range
Problem with main fan oven - electric
there is an overheat stat and this is operating and cutting out the oven. the causes are several but here are the main things to look for: oven stat is faulty causing the oven to overheat. you should check over the range to see if stat is reasonably accurate. overheat stat itself is faulty. there is another stat which turns on the casing fan. (this is the fan which is out of sight - not the fan inside the oven) if this stat is faulty and not turning on the casing fan, then the overheat stat will operate. the casing fan is faulty or jammed. lack of ventilation. see if you can narrow it down a bit and get back to me if you wish
May 06, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
12 people viewed this question
Top Belling Kitchen Ranges Experts
paulcarew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
