Question about Acer Aspire 5610-4648 Notebook
Repair Acer 4937 MBR failed !! - Acer Aspire 5610-4648 Notebook
  • Acer Master
  • 13,433 Answers
With MBR I assume you mean master boot record.
  1. Restart your computer with the Windows XP Setup disk in the CDROM drive.
  2. If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive.
  3. after a few minutes, you'll see a prompt to press the R key to start the Recovery Console.
  4. When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases,
  5. you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer.
  6. Enter your Administrator password. If you don't enter the correct password, you cannot continue. You can leave it blank if you don't have one.
  7. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed.
Your MBR will be replaced with a new one, and you should then be able to start up normally. In some cases, you may need to repair the boot sector in addition to the MBR. If your system still doesn't boot properly, repeat the steps above, but issue the fixboot command instead.
Exit, quit, restart or reboot command should get you out from the console
If the problem is still not solved, use the windows xp setup disk to do a new installation of windows, if it finds your old windows version from the hard drive you may repair it with the repair option (not the same as above)
Posted on May 22, 2009
My acer aspire 5515 laptop system error window show when I try to boot. Hiw do I fix it?
so what i guess its giving mbr not found and its not booting , the solution is you need to have the windows operating system disk and then when your acer laptop starts to boot click on f8 then click on repair windows then after that you will see 3 option click on the third it will say repair cmd then type as what is given below
Click on the "Repair Your Computer" option to gain access to the System Recovery window. Now choose "Command Prompt" to run the Bootsect.exe utility. Bootsect is located inside the boot folder so change your directory to boot. Now run "bootsect /nt60 C:\" (without quotes) if you had Windows 7 initially installed in the C partition. Alternatively, you can run "bootsect /nt60 SYS" or "bootsect /nt60 ALL" (without quotes) to repair the system partition or all partitions. Eject the DVD and restart your computer. Your computer should now boot Windows 7 again.
Read more: How to Repair the MBR on Windows 7 ' eHow.com http://www.ehow.com/how_4836283_repair-mbr-windows.html#ixzz2CY96TyX0
Nov 18, 2012 | Acer Computers & Internet
Computer screen reads "reboot and select proper boot device, or insert proper boot device"
Do you have a USB drive attached or a disc in the dvd drive that may be causing a problem?
If not your MBR may be damaged.
You can fix this with a windows disc, just google "fix MBR"
If you dont have a windows disc, you may be able fix it with this site http://www.softwaretipsandtricks.com/forum/windows-xp/27414-repair-mbr-without-xp-cd.html
Oct 16, 2010 | Acer Computers & Internet
I want acer Aspire 4937 drivers
Download the drivers from the Acer WEB site. Make sure you select the model of your laptop and the XP or Vista version of the drivers you that require and it matches the Windows version that is installed on your laptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Jul 23, 2010 | Acer Aspire 5610-4648 Notebook
Disable HDD password feautre on Acer 4937
You should be able to change the password and just leave the new password entry blank. This should efectivly clear your HDD password.
Jan 15, 2010 | Acer Computers & Internet
Acer aspire 4937 touch keys at the side not working
the best practice is go back to the dealer to fix it under warranty, rather than missing with it and void warranty
Dec 30, 2009 | Computers & Internet
How to open acer aspire 4937 camera
download the webcam driver from
www.acer.com and then use webcam
in the xp2 the webcam driver is inbuilt
Sep 12, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 4937 Multimedia Controls not working
i see now that you are using windows seven, it would definitely not.. 40% people using this kind of windows because its very fast than vista, but the problem is some hardware or device are not compatible with this... so maybe you have to put windows vista, i assure you, your multimedia controls are working....
Jun 19, 2009 | Computers & Internet
Looking: Acer Aspire 4937 Launch Manager that work with Windows 7
right click on icon for vista version of launch manager and click trouble shoot compatibility. click on vista
Jun 15, 2009 | Computers & Internet
Repair D2D Recovery Acer 4937 MBR failed !!
choose to boot on the vista partition and imidiatly press F8 several times to get the vista boot menu.
choose "repair computer"
choose language,
choose user (and type in password if there is any)
see if there is a option called something like
ACER recovery /factory image / something similar (usually the bottom option)
if there is, click it and start recovery.
if there isnt i would contact acer and have them send me a new recoverysett. (4-6 weeks deliverytime)
May 22, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610-4648 Notebook Logo
400 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
