Question about Chauvet LED PINSPOT 2 LED LIGHT (Chauvet)
Lights that aren't supposed to flash are flashing eratically
2 of them have begun flashing erratically, while the other 2 are working constantly as they should. They aren't plugged into a chaser. Is this a warning that they are about to go out?
How to chech erratic fuel gauge 90 van dura van.? Up and down behavior
faulty fuel gauge sender unit, inside your fuel tank,bolted to the top and hangs down inside,uses a float and arm to give signal to fuel gauge.
Mar 02, 2015 | Cars & Trucks
Electrical issue
Sounds like a poor connection at the battery or alternator. You need to make sure there is no corrosion or faults in these connections. If there is no fault there then you likely have a ground problem. Find your engine/Chassis ground, make sure it's tight and again free from corrosion and fault. Leaking battery acid can eat wires on the possitive and ground causing issues. Also if the car has been in an accident it could also have damaged or lossened the ground.
Jan 16, 2014 | 1997 Honda Civic
Help for the airbag icon flashing -- is it obviously serious, or could it be a wiring issue or other simple fix? It has just begun a system of multiple flashes and then off for several minutes OR a solid...
upon ignition on the airbag diagnostic module will scan the system for any fault, if there is a fault the airbag indicator will flash. The first set of flash signifies the first digit then a pause the next set of flash for the second digit.Combine these two digits denotes the fault code i.e (two rapid flashes means 2 then a pause followed by three flashes means 3 combine these will read 23 this is the fault code but you need to consult this in the repair manual for ford cars to get the particular fault.Repetitions of 5 sets will occur then steady light on for the airbag.Just replace the instrument cluster and replace the busted bulbs for odometer and turn indicator
Feb 01, 2010 | 2003 Ford Escape
Acer ZG5 lsass.exe Part 2
you need a bootable image on your flash drive. if you ve just copied the cd files the USB wont do a thing and the monitor will keep blinking. what is the exact problem?
Jul 24, 2009 | Acer Computers & Internet
Kyocera FS 1020D
You might be out of toner.
Jul 22, 2009 | Office Equipment & Supplies
Starter does not engage.when key is turned gages are eratic?
check battery voltage it should be 12.5 volts.if all is good .you have a bad starter or starter solenoid switch.i
Apr 24, 2009 | 2000 Pontiac Grand Prix
Crazy clicking/flashing lights
There is a bubble shaped sensor on you center dash near the windshield. It may be dirty, blocked, or broken. If you hear a high speed click and the lights strobe pretty quickly, it may be a bad relay. Last, you may have a bad ground. But - I doubt it since the lights work fine when not in Auto mode. I would start with the sensor then relay.
Apr 24, 2009 | 1998 Jeep Grand Cherokee
I had a viper 5701 responder LE 2 way system installed on my 2006 dodge Dakota, everything works fine but my headlights and parks lights stay on constant while in remote operation and my park lights do...
If your vehicle has daytime running lights they will be on when remote started no real way around that try leaving your parking brake on.
The new vipers default setting is constant rather than flashing.
Dec 17, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Chauvet LED PINSPOT 2 LED LIGHT (Chauvet) Logo
47 people viewed this question
Top Chauvet Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Chauvet Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
