I need a manual for a uet 609 remote control for a bush t.v
I need the code for a bush tv using a uet609 universal remote control
5 Suggested Answers
SOURCE: uet 609 remote control
Yes .. ReadTheManual
Posted on Sep 12, 2008
SOURCE: i need to know how to program uet 609 remote to my tv
philps dth 200/05 what the code
Posted on Apr 04, 2010
gopakumarg43
  • 75581 Answers
SOURCE: uet-606 universal remote control code for comet tv
Just do a code search method. It will be best rather than try to get the code list to this remote control. If your remote control have pre-programmed codes for your device, this method will help you to synchronize it, and you can retrieve the code too. Procedingns are given.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Posted on Jun 24, 2012
shresthasanj
SOURCE: I can not start using my universal remote control UET-606
i need to Aftron tv code
Posted on Oct 09, 2012
I need remote code for bush tv
try a search for yourself on Google this is called self help .
Aug 25, 2015 | Universal Televison & Video
Bush tv code for uet609
092.097.099.000. Check these codes. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 05, 2013 | Televison & Video
How do I find out the code to use my remote with a bush tv?
hi
bush codes are one of the following,1916,0294,0556,0714,1900,0698,0617.0614,0217,0208,0487,1037.
0361,0264,0374,0363,0355,0282,0371,0037,0036,0009,0163,0218,0668,
regards Derrick
Mar 14, 2010 | Televison & Video
I need code for my nse urc22b-10 universal remote control
i have a panasonic tv i want code for urc-22b-10 remote controler
Oct 07, 2009 | Teac RC-L2 LCD Touchscreen Remote Control
I NEED TO KNOW HOW TO GET AND WORK CODE FOR UET609 UNIVERSAL REMO
n these remote controls any device key can operate other device types because coding is by selecting a number from a list ranges for UET609 - tv: 000-268 and 700-758, vcr: 269-370 and 750-758, sat/cbl: 371-523 and 800-883, aux (cd, dvd etc): 524-699.
As there are 800 codes, select the appropriate device before searching for a code! This presets the start position in the search.
To set a code:-
Press and hold [set], press device key - red led lights. Release keys. Enter 3-digit manufacturer's device code from the list. Led goes out and the code is set. If it doesn't work try another or search.
To search for a code:-
Turn on consumer device!
Press and hold [set], press appropriate device key - led lights - release keys - press [set] - led blinks. Press [power] key repeatedly till device is switched to standby - press device key to store the code. If, after releasing the keys, [set] is pressed twice, search runs backward through the list.
Having found the code, it may be useful to write it down, as follows. Press and hold [set] - press [1] and release. Count and record the number of times the led blinks - release [set]!. Repeat for [2] and [3].
Note! The above information is from the manufacturer of the remote controls. In practice, things may be a little different i.e. on the UK Sagem digibox [power] is digit 1 and the power key is [tv/txt]!
These controls can be regarded as old stock and may not contain codes for digiboxes and DVD drives. However, surprising things happen, if a manufacturer is using old codes. The Goodmans GDB3 digibox can use UET609 sat/cbl code 424 and the Sagem ITD59G can use unlisted code 836.
To repeat, the protocols and associated key codes are referred to by a 3-digit control code, taken from a list of 800. You should find the necessary code fairly quickly - within 100 tries, if you select the correct device type.!
There is at least one more remote control in this series and operation should be the same, though the key layout varies between models.
At times, these remote controls can malfunction.
Red Led stays on - Remove the batteries and re-insert them.
Remote Control suddenly stops operating - make sure correct device key is selected. If necessary, re-enter the relevant device code. If this fails leave the batteries out over-night and re-enter the codes.
Codes: 044,054,119,124,196,198,225,227.
If it works vote for me
Aug 17, 2009 | Televison & Video
Bush tv remote code
did you get this sorted? Im having the same problems with my tv and that remote!!
Jul 04, 2008 | Televison & Video
Remote control code list
The Konig IR9982 is not a universal remote control so there is no code to make it work your Bush TV. It is actually a direct replacement (electronic clone) remote for some Hitachi models.
You will need a direct replacement for your particular model, try http://www.remotesreplaced.co.uk/television/remote-control-bush.htm
Feb 19, 2008 | Universal Remote Control DIRECTV Universal...
In need of tv codes for ge romote control
You don't need a code. Just follow the instruction as follows:
1. Tun on TV
2. Press and hold "code search" until light stays on, then release.
3. Press TV botton
4. Press on-off repeatedly until TV turns off
5. Press enter.
That is it. It works for me.
Oct 22, 2007 | GE JASRM24912 Remote Control
Bush tv remote code
i have a bush lcd tv 27 inch an its stuck on stand by i have an urc7740 one forall remote how can i take my tv of stand by with this remote.
Aug 26, 2007 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
