Question about Stoves Premier 600EMa Electric Single Oven
Change element - Stoves Premier 600EMa Electric Single Oven
Why isn't my oven working? After changing bake element and thermostat
Either the bottom element is defective or the wiring to it is not hooked up properly so it gets power and does its job ala the top element.
OR the control that is responsible for having power delivered to both elements is only sending power to the top element. Make sure you are not using the broil setting since that only activates the top burner.
Feb 03, 2016 | Ovens
Tip
How to diagnose, fit and change a Belling fan oven element
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ. Belling Elements
on Aug 25, 2010 | Belling XOU492 Electric Double Oven
Tip
Belling Elements
on Aug 25, 2010 | Belling XOU592 / XOU593 Electric Double...
Bake element fell apart. Changed it out with replacement element (Emerson CH 5862 PCN 458580, 240Volts, 2800 Watts) Still does not work.
As a general rule, when you change an oven element, you should change the thermostat as well as the element failing can sometimes take out the thermostat as well. (Info. courtesy of a NEFF engineer many years ago as they always change both if an element fails).
If you haven't done so, I would suspect the thermostat.
Feb 06, 2010 | Ovens
Oven's bottom heating element does not heat
this should show you how to change it
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
The main fault when the oven is not heating is that the element has blown here is a video on how to change your fan oven element and the motor.
For all your fan oven element click here
Jan 07, 2010 | Frigidaire Ovens
Tip
on Aug 25, 2010 | Belling XOU482 Electric Double Oven
Tip
on Aug 25, 2010 | Belling XOU252 Electric Single Oven
CHANGE OVEN ELEMENT maytag mer5555qaw
Are you wanting to change the element? Bottom element is part # 74011117 and the top is broil element part # 74008692 If you need help let me know, Thanks,Sea Breeze
Mar 23, 2009 | Stoves Ovens
Tip
on Aug 25, 2010 | Belling XOU174 Electric Single Oven
Tip
How to diagnose, fit and change a Belling fan oven element.
on Aug 25, 2010 | Belling XOU270 / XOU271 Electric Single...
Stoves Premier 600EMa Electric Single Oven Logo
12 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
