Question about Watches
Setup a28 frog watch - Watches
Purchased a fossil FS4930 2 days ago and there are no instructions on how to setup or use the watch. ' f
Do you have any possibility to get one from store where you bought it? I've been searching for an online manual but couldn't get any, just these two videos
Men Fossil Grant Chronograph Leather Strap Watch FS4930
Ceas Fossil Grant FS4930 Review Fossil Grant FS4930 Unboxing
Jun 26, 2015 | Fossil Watches
Need to set time, etc on this 3 button watch
Hi
I have found a PDF document that contains instructions for all ladies Armitron digital watches it can be found here. It dosnt however contain instuctions for your model, but most of the watches it covers have the three button setup and may fucntion the same way.
Hope this helps
Mar 07, 2011 | Armitron Digital Sport #45/6967PNK Watch
Hi, My Tissot touch watch quit, it was just over 2 yrs old, and I took it to the local Jewelry Store that sold them. They sent it off to their Jeweler and he replaced the battery. Now the watch keeps...
If the Jewellery Store was not an Authorised Tissot Repair Centre then it is likely that they have made a mistake - the T-Touch is the only watch in the world that has a touch screen - so they may not be very familiar with it.
It may be going into setup mode because there has been a new battery just installed - go through the procedure and see if it works. - Pretend it is like brand new and you have to set it up for the first time.
Dec 14, 2010 | Tissot T-Touch T33159851 Wrist Watch
How to setup the alarm to my tag formula1
I couldn't locate your model but if you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1113.BA0850 , you will find the details of a similar watche. In the menu at the side you will see "instruction manual".
Jun 03, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
How to set a La Crosse radio controlled watch Model # WT-961(S) 12-24
Go to http://www.lacrossetechnology.com/support/setup.php and choose your watch from the drop down menu.
Unfortunately they do not have any instructions but there is a contact address there where you can get help.
May 09, 2010 | La Crosse Radio Controlled Watch
How to setup the watch
There are 2 buttons on the right side, depress the lower round button twice with a pointed object (like a pen). Only one number should appear (month) advance if desired with the top square button. Depress the round button again (once) to advance to next number and advance, continue this until you complete the settings.....
Apr 07, 2009 | Kenneth Cole KC2315 watch
Cannot get invicta atomic watch setup . Can get the electronic l.e.d. setup with the correct time. I cannot setup the regular dials to do the same. I think it has to do with using the correct Time...
Here is the link to Invicta watches:
http://www.invictawatch.com/
Choose SERVICE and click on relevant tab to find out instructions.
As this is the only site on internet, there isn't much more I can do for you.
Don't forget to rate, please.
Jan 13, 2009 | Bulova Watch
Discovery croaking frog clock
I have the same problem about the frogs not croaking. Is there any place you can purchase a new clock? I love the clock and miss the frogs!
Dec 30, 2008 | Watches
The setup button doesnt seem to do anything
There is nothing to do with battery. You have dirty setting button or oxidized plate contact or weak pushbutton spring. To fix that you have to dismantle your watch.
Take the movement out and clean the pushbutton in case from both sides with tiny brush and lighter fluid (Zippo). Dry out with dust blower. Get small steel pin and clean (scrape) coresponding contact on plate clean of any visible residue. Use dust blower again. Strengthten coresponding contact spring by slightly pulling it outwards. Reassemble watch.
Good luck
Dec 13, 2008 | Suunto X Lander Military SS012926110...
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
