Question about Asrock H55M-LE LGA1156/ Intel H55/ DDR3/ A&GbE/ mATX Motherboard H55MLE
Rear usb not working - Asrock H55M-LE LGA1156/ Intel H55/ DDR3/ A&GbE/ mATX Motherboard H55MLE
I don`t connect with usb of PC. The USB port not reconigze it
use only the rear USB port of desktop, because by using any extension or hub there is a voltage drop so that why it is not recognisezed, only use the rear USB port and use the orignal cable or branded product USB cable, loose cable also dont work with it.
Feb 14, 2010 | SimpleTech SimpleDrive 160 GB External USB...
ONE USB PORT ON BOARD REAR FIXED TO BOARD NEXT TO
Make sure they are all turned on in the BIOS. Check your manual for jumper settings too.
Dec 24, 2009 | ASUS A8N-E Motherboard
I need a usb 2.0 driver for my biostar U8668 mother board
when u power up the computer press "del" or F2 kewy to tenter in bios then go to usb configuration then set high spped in usb 2.0
May 06, 2009 | Biostar U8668 Motherboard
Gateway gt4010 usb ports are all failing.
It's your hard drive going bad! I had the same problem in my company. Could not figure it out but when i flopped the hard drives they started working agian.
Mar 26, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
The 4 USB Ports in the rear stopped working. Can they easily be replaced?
hi there,
the rear USB port cannot be replaced, & glad that you still have a front USB connections into your MOBO..?
May i ask why did they suggest you to use the front USB panel..? Can you give us some info why this was happen..?
Thank you
May 27, 2008 | PC Chips M957G Motherboard
Usb not recognized on sansa e280 (sandisk)
Unfortunately, so simple - although this simple solution does not appear in any manual. the solution: put your Sansa in the rear USB - and the PC immediately recognizes the MP3 or MP4. The USB soccket in the front of the PC does not have enogh power, and when using the rear USB port - it works!
Izi
izimann@lycos.com
Apr 04, 2008 | Audio Players & Recorders
Front side USB port is not working
On some computers the front usb ports are like a usb hub, they don't have enough power to power up a hard drive.
Nov 04, 2007 | ASUS M2N-MX Motherboard
Problem in connection to a PC
in spanish.... use translator please ya revisaste el cable usb? el usb es front o rear, probaste usarlo en otro diferente o en otro equipo?.... si funciona... pude ser problemas de configuracion del sistema operativo y habria que reinstalarlo, si es cambiando el usb, generalmente los front son 1.1 y los rear 2.0, si aun presenta problemas usa un driver lo mas actual posible, no el que viene con el hardware... y si no uffff soporte tecnico del fabricante.NVV
Dec 11, 2006 | Fujitsu TeamPad 500 (pbt500-13) Portable...
Asrock H55M-LE LGA1156/ Intel H55/ DDR3/ A&GbE/ mATX Motherboard H55MLE Logo
23 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
