Question about Velodyne CHT-12 Subwoofer
Wiring diagram Popping noise
Why is the trunk popping open and making clicking noises.
Hi april, I was a ford tech for 15 yrs. It sounds like your latch mechanisim is out of ajustment. The clicking noise is the solinoid thhat opens your hatch. There is a switch in the latch. Unless your hatch latches and closes tight, any small bump will jar the hatch the switch opens and pop goes the hatch. It should be a very ez fix, your corner machanic should have you all set in 30 mins or so. At worse case your latch may be broken and it just won't stay latched. It does happen but it is rare. Btw, if you do need to replace the latch, shop a junk yard first, you'll find one there a lot cheaper than your dealer.
Aug 31, 2014 | 2003 Taurus & Mercury Sable Factory Wiring...
Popping noise from engine
Timing is off or bad plugs points or wires start with a tuneup if you already did that then check the plug wires you may have one crossed.
May 26, 2014 | 1975 Volkswagen Beetle
Fuel tank popping noise
Does it do it if the cap is off?
May 02, 2017 | Autometer Science & Laboratory
Popping noise on Polaroid 32"
Bad connection to your TV/Video source. Check your wiring for bad/broken wire or connector, or poor connection to the TV.
May 02, 2011 | Polaroid TLA-01911C TV
Popping noise from the subs
check rca wires you should spend good money on these it will help with road noise
Mar 25, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
Popping and Humming noise from my audio system?
Ground Loop Isolators are nice, but if you want truly crystal clear sound, you will need to run a common ground. All electronics will need to be run close to the amp, as more than about 3 feet of ground wire from the amp can cause sound issues. When I ran my common ground, I connected my radio and satellite together, and ran one sigle ground wire to the backseat of my car, where the amp grounds are located. This will optimize the clarity of the sound coming through the speakers. For the popping sound in the speakers when the car is powered on or off, you need to see if the radio itself has a wire to power the remote connection on the amp. Most of the time, they will, and this is the wire you will use to turn on the amp itself, as it delays each item powering on and reduces the chance of popping in the speakers. DO NOT run the remote wire from the amp to the accessory wire of the radio, as this will cause the popping sound you are hearing. If the radio does not have an Amp Turn-on wire, then you may need to improvise by using an accessory wire in another location, but even this is may cause popping as well. The pop comes from multiple things turning on at once, so the Amp Turn-on wire delays the amps for just a moment, preventing the pops.
Oct 05, 2009 | Pioneer DEH-P6400 CD Player
Kenmore microwave loud popping noise when start
That sounds like maybe a high voltage wire or component is running too close to the chassis or one of the components connected to it.
Gruesome as it sounds, sometimes a pest can get inside the works and can move wires around or be killed, then its carcass can conduct electricity and cause arcing.
It may instead be a failing high voltage diode.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number (66562619200) at the Sears parts site.
Here are some links you or someone you know can use (in order given) for test help, but
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
Jun 14, 2009 | Whirlpool MH7130XE Microwave Oven
Dishwasher made a popping noise and all the lights...
the connection at the bottom of the dishwasher where the house wiring meets the dishwasher wiring is probably melted. you would need to cut back the burnt wires and re-splice it..
Mar 13, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Popping noise
Its a wiring issue. Check the wiring harness (if used) and make sure all wires are intact. Same with the wires at the speakers. Make sure all speakers and head unit are properly grounded. Hope this helps!
Aug 14, 2008 | Pioneer TS-A1057 Coaxial Car Speaker
Velodyne CHT-12 Subwoofer Logo
46 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Matthew Spark
Matthew Spark
Jerry Greenberg
Jerry Greenberg
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
