Question about Frigidaire Dryers
FASE7074LA0 E61 E61 error code after running for 2 minutes
2 Suggested Answers
protek480
  • 1723 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Posted on Sep 25, 2009
Frigidaire affinity dryer error code e61 after running for five minutes. Have replaced the control board already. What does it mean?
Others have had the same question. These urls ( both current as at 2018-02-03)
http://tinyurl.com/yaomkjxo
and
https://www.youtube.com/watch?v=plVN4ssa138
throw light on it.
Consensus is that E61 is a heater fault, in which case nowt to do with the board, but likely an open circuit in the heater element. Easy to check with an ohm-meter. Board diagnostics are correctly saying "I've been on for a few minutes but detect no heating..BAD". Keep the old board - it's likely fine.
Feb 02, 2018 | Frigidaire Dryers
I have a Frigidaire Affinity electric dryer model number FASE7021NW0. It suddenly began giving error code E61. I called frigidaire. they said it was likely a shorted wire and put me in contact with an
I appreciate your post, Doug Anderson! From the information you have provided your Frigidaire dryer is displaying an error code of "E61". "E61" stands for heater relay failure which could be a problem with wiring, heater relay, or main control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord for ten minutes. This should help clear out any potential false error codes. Hope this information is helpful. -Matt
Dec 20, 2014 | Frigidaire Dryers
Error code E61 shows on my Frigidair Affinity washer. Do you know what E61 Means?
Hello Murray;
My name is Peter. I am a retired field service appliance technician.
Hi E61 means that the control board is sensing an incorrect/abnormal voltage present at its input.
1.) Unplug the unit for 5 minutes. If the error comes back -
2.) Lets check your power cord:
a.) Unplug the machine. Is the middle connector on your power cord connected to 'N'?
b.) Tighten all the connectors. Make sure you have a good ground.
c.) Check the voltage. Between 'L2' & 'N' = 110V, 'L1' & 'N' = 110V, 'L2' & 'L3' = 240V.
3.) Lets check your control board for shorts:
a.) The following link will show you how to access. Ground yourself by rubbing your hands on bare metal. Static electricity will knock out a board.
b.) Check all of the connections, push in on the wires at the connectors.
c.) Reassemble and try to start
http://www.applianceblog.com/manuals/5995413084_Washer_2004.pdf
4.) Well, if none of the above solved the problem, you have to replace the control panel.
Part #: 134523106 - Cost: $168.00
Dec 08, 2014 | Frigidaire ATF6000ES Front Load Washer
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post!
If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website.
Best regards.
Apr 25, 2014 | Frigidaire Dryers
Error code loc
Hi Amanda, thank you for your inquiry!
An error code E61 generally means that a heater relay failure has occurred. A qualified technician would pinpoint the problem by checking the wiring for both open and short circuit across heater relay(s). If the wiring isn't the issue, he/she would need to determine whether the problem rest with the main control board. It really could be a hit or miss calculation in parts so I would personally reach out to an experienced tech that will be able to identify the precise reason.
Dec 01, 2013 | Frigidaire Electric Dryer
Electrolux
Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
May 01, 2013 | Frigidaire Electric Dryer
Sep 25, 2009 | Electrolux EIED55H Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
