Question about Beats By Dr Dre Beatbox iPod Dock
Bass no longer working
For no reason at all, after only a year of relatively light use, and not loud over use due to where I live! I now have no bass and my once amazing sound is so bad, I will no longer use the Dr Dre Beatbox as it sounds like a tinny radio from the 80's!! Anyone experience this problem and know a fix or know an outlet that will fix it, eg Richer Sounds? Can't return it as from HMV and was a gift so I've no receipt and warrantied items therefore have to go back to the US which is useless to me in the UK!
Bass sounds are extremely loud and distorted. Do I have to send the set in for repair under the warranty?
If you can't adjust correctly bass, at a comfortable level and without any distortion, for sure you should return it on warranty!
May 04, 2015 | Mackie Onyx 32.4 Premium 32-Channel Analog...
I have a vsx-821-k reciever and cant adjust the bass
If the treble is good and is working then the failure to adjust or increase bass output even when it is done can be due to faulty OP-AMP in the BASS circuit. The BASS frequency must be enhance with an amplification and a pass filter with amplification boost and so a failure of this stage can be the reason for non action.You will need to have a signal test on the bass section to confirm the faulty IC.Check for poor solder joint and faulty capacitors/controls.
Dec 14, 2011 | Audio Players & Recorders
Hi, I have a Kia Sorento model year 2006 (EX). This car has a random problem related in to electricity. This problem does not occur in the winter, I live in Finland. Central locking does not work....
its a kia and these vehicles do suffer from electrical problems as you describe although less here in spain but immobilisor faults are common and if it will not start due to immobilisor then lock vehicle and leave for half hour or so and then it will go again ---why--- ????
May 29, 2011 | 2006 Kia Sorento
I have a Kenwood 1050sw subwoofer that will not work. The power light comes on buy nothing happens. Last time I used it worked okay, then I replaced my receiver and didnt hook up my sub til about a couple...
Tell us a bit about your NEW RECEIVER. I'm sure the manual explains how to set up and direct bass to a subwoofer.
Basically, you have to inform the receiver it HAS a sub, then you define the ability to share bass with it, then you adjust relative loudness with a test tone and you're off.
Retrevo.com is where I get most of my manuals.
Jan 16, 2011 | Kenwood 1050SW Speaker
Hi, do you know if you can adjust the bass on a Sharp xl-hp505 micro component system (other than the preset settings)? I find the bass too loud. Thank you so much.
The manual mentions a couple of things that could account for excess bass, one being the Extra Bass button (X-Bass indicated on front); the other being the ROCK setting, which boosts bass.
http://www.retrevo.com/support/Sharp-XL-HP505-manual/id/285dj790/t/2/
Placement of the speakers relative to the room surfaces and the listening position can affect their perceived bass response. Experiment. Corners and close wall reinforce the bass, moving the speakers out from them would lessen it.
Jan 03, 2011 | Sharp XL-HP505 CD Shelf System
My infinity ps210 stops putting out any bass. It was working fine a few days ago but it just stops working without any obvious reason. I bought it fourteen months ago from amazon and I've hardly used it....
Hey. I have two PS210's One popped and stopped working 9 months in to it. Under warranty the technician said that Infinity produced these speakers wit ha known heat related problem. Some part burns up. He replaces them all the time. You can expect about a year's service as my seconf one just popped and died. It costs about $153 to fix it here in phoenix. Will never buy Infinity again from what I know
Sep 04, 2010 | Infinity PS210 Subwoofer
Why my 5.1 logtechx530 bass not loud on dell laptop vista
Hi there , It could be that someone . or default ..has changed your Eqauliser Settings in Vista, By this i mean that Bass Selection and how loud you want it...
Try setting it higher that should work
Happy new Year Bud
Dec 28, 2009 | Logitech X-530 Computer Speakers
Servo light off but no bass
you must have lost power to your servo check all fuses and insure you have voltage up to the fuse
Feb 24, 2008 | Infinity BASSLINK Car Subwoofer
Subwoofer Bass Level Problems
What is your sub stood on? If it is on a piece of furniture then this could be the problem. Bass frequencies travel further than higher frequencies due to their longer wavelength and will also be transmitted through any solid objects the speaker is in contact with. The solution is to mount your sub on a piece of foam to provide some damping.
Also if your sub has a port (a hole) on the back or side this needs to have a good 3 or 4 inches clearance from nearby walls or panels.
Finally the speaker cone itself needs to have a clear path to push sound energy into the room, if this path is blocked by furniture (some people like to hide them under tables) then it may make that furniture vibrate.
Nov 26, 2007 | JBL SCS200.7 Home Cinema Package System
Beats By Dr Dre Beatbox iPod Dock Logo
Top Beats By Dr Dre Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike
Tom Chichester
Are you a Beats By Dr Dre Audio Player and Recorder Expert? Answer questions, earn points and help others
