Question about Nintendo Wii Console
Nintendo Wii, connection error while sending user agreement
I succeeded to connect my Wii to my wireless router (I assume that since the system was updated successfully in 20-30 minutes after establishing the first connection). Then each time I tried to review and agree the user agreement section, it gives me "Error Code: 51330, internet connection error". I checked the error code and found out that people gets this message while trying to establish the first connection. But as I had succeeded to download the system update, this shouldn't be my case.
It is strange though because after turning off and turning on again my wii console, if I try to update the system first, it connects and few minutes later says that no update is necessary.
In short, my wii console can connect to the internet for updating purposes, but fails to send my agreement for user agreement section due to a connection error.
What may be the reason of that error?
Many thanks in advance.
    Genius:
  • 1,234 Answers
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Posted on Aug 27, 2010
I can't get connected to Netflix. I keep getting error 51030
That sounds like a Nitendo Wii errorcode; assuming your using that to watch Netflix:
From the tech support website: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=en_US
Error Code: 51030
Unable to connect to your wireless network
Likely cause: Your wireless router may need to be power cycled, or the connection settings have changed.
How to fix: Power cycle your router; redo the connection settings on the Wii and try again.
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
  • Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected. We suggest following our guide to create a new connection file and start over. If at the end you still need help, you'll find contact information to reach our specially-trained representatives.
Click here for info on setting up your Wii: http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
In other words; you Wii doesn't seem to be connected to your WiFi network anymore ...
Jun 29, 2014 | Netflix
I have a problem with my internet settings. I would like you to help me with my connection, because its keep saying the error code and then it has numbers, and also says unable to connect to the internet....
You have to go to your internet connection settings on the Wii, and load the user agreements, accept them, and connect to your wireless internet.
Aug 17, 2011 | Nintendo Wii Console
Not connected to internet error code 51030
According to the following knowledge base article, this is a common problem. http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=en_US
Please try the following steps in this order to try to resolve the issue.
1. Power off your Wii completely. Disconnecting it from any power source. 2. Unplugged your internet modem/router and wait for 10 seconds. 3. Connect your modem, wait for 10 seconds. 4. Connect your wireless router, wait for 10 seconds. 5. Power on your Wii and visit the Wii menu. 6. Test your internet settings.
If the error still persists, try deleting the wireless settings on your Wii. Then, recreate them after verifying that they are correct and match your wireless router's settings. If you need further assistance, follow the link to view a step by step guide provided by Nintendo to assist user's with connecting their Wii's to wireless access.
Jul 27, 2011 | Nintendo Wii Console
How do you set up Internet on the wii?
To access the internet with your wii console you'll need either a wireless router/gateway, or a wii wired LAN connector.
1. Power on your Wii console
2. Access the "Wii Setting" menu by selecting the circular wii icon in the bottom left of the screen and then choosing wii settings.
3. Use the arrow on the right of the screen to move to page two, then select "internet".
4. Select "Connection 1 ' None"
5. Choose "Wireless Connection" (assuming you have a wireless router), then select "Search for Access Point".
6. Wait for your wii to scan, then select your wireless network, and if prompted enter your wireless network password/key. Then click "OK".
You should now be able to connect to the internet. If your Wii runs a connection test and it proves unsuccessful it will display an error code. If you get Error Code 51330 or 52130 this means the password you entered does not match the password on the wireless network you are attempting to join. A list of all other error codes and what they mean can be found here: http://www.nintendo.com/consumer/systems/wii/en_na/onlineErrorCodes.jsp
Jul 24, 2011 | Nintendo Wii Console
Cannot connect to Internet Error code 220602
Hello there!
There are a couple possible options to fix your problem that may work:
  • Temporarily disabling WEP encryption on the router.
  • Set up another internet connection profile on the Wii (w/o encryption key)
  • Select the User Agreement on the Wii.
  • Re-set the WEP encryption key on the router.
  • Switch back to the internet connection profile on the Wii (w/encryption).
I would try all of these and hopefully your problems will not persist. Good luck!
Jun 17, 2011 | Nintendo Wii Console
I have the code 220602 coming up on the wii and cant get online
Try these steps:
May 02, 2011 | Computers & Internet
Trying to connect to internet and its reading error code 220602.
Sorry to hear your having issues with your wii internet. One solution you can try is to:
Disable encryption on your router. Set up a new wireless network profile on your wii and then connect to it and do not use encryption. Accept the user agreement when it pops up. Then set up the encryption again on your router and try to connect using the encryption key.
Apr 27, 2011 | Nintendo Wii Console
Connectin to internet
hi ,
maybe you forgot to set the user agreements
try doing that and then try doing it again
hope this help
Aug 16, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
241 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
