Bought Samsung 2233BW Monitor, hooked the two plugs, power and DV1 cord started computer and switched on monitor, NOTHING HAPPENED. Silly thing just unhooked Samsung and hooked back up the AOC monitor no problems
    President:
  • 2,992 Answers
You might need to go into the monitor's setup menu and select the digital input. (That's DVI, by the way, for Digital Video Input, and not DV1.) Some monitors automatically detect the input but not all of them. Obviously, this doesn't apply if the Samsung has only a DVI input. It might also be necessary to tell the video card to turn on the DVI output. You can do this with your old AOC connected and use the video setting utility supplied with the video card.
Posted on May 22, 2009
Samsung Syncmaster 2333
Check signal cables means there's no signal on input. If your PC still shows up on a different monitor then it's a time to replace a mainboard in your monitor.
Jun 03, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung SyncMaster 2233bw monitor refuses to work at all
This usually indicates a failure in the power supply board. Here is a link to a repair kit for that board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=116
I hope that helps, if so please rate my solution.
BuddyMc
Feb 11, 2012 | Samsung SyncMaster 2233BW 22" LCD Monitor
Hi, I bought my samsung 2333 syncmaster in the U.S. but moved to New Zealand where the voltage is 230, can I use the monitor with a converter plug or with a NZ compatible cord?
Samsung 2333 have switching power supply and it can work from 100-240VAC 50/60Hz with out any modification or adaptors. Feel free to use it in USA or New Zealand. You need only to arrange plug converter. Check specifications on Page 49 of 2333SW user's manual available on: https://www.manualslib.com/manual/201694/Samsung-Syncmaster-2333sw.html?page=11#manual Samsung SyncMaster 2333SW User Manual Your Monitor Initial Settings
Jun 03, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Just hooked up computer and monitor and cant get any sound to play through moniter. do we need external speakers?
The Samsung SyncMaster 2233BW does not have built-in speakers, so yes, you need external speakers separately for sound.
Feb 06, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor to black, power LED blinks, hard re-boot and it works
Take a look at your power saving settings. It sounds like the monitor is set to sleep after 20 or 30 minutes. You may want to change your setting to "never". The settings are under Control Panel - Power management
Aug 15, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
No display
try this ,unplug power cord turn off computer, (if you have switch) there should be no electricity. Remove little battery that you have on your board,wait for 10 sec. and pull it back in, that will restart cmos to default values.PLug power cord, turn on computer. Post me what happened.
Jun 09, 2009 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
New acer 19 " moniter plug in will not turn on ?
Try other outlet, check the power cord if it contacted the monitor. If nothing happened, maybe it's factory defect, since it still under warranty, you can still change it.
Thanks
Nov 09, 2008 | Acer AL1717 17" LCD Monitor
Monitor light blinks
have you tested the power supply connection feeds? test each connector I think you will find your power supply has failed on either the 5 volt or the 12 volt side more than likely 5 volts are down' the agp adapter needs 5 volts to run. since you have changed out every thing else I would replace that or test your dads power supply in your computer, that should do the trick
Apr 28, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
