Question about Whirlpool Dishwashers
Start light flashing
The start light is flashing. I have cleaned the filters etc and it hasnt helped. If I hold the start button in, the dishwasher starts trying to take water in but then the pump starts and it pumps any water back out straight away.
  • janet_bald May 22, 2009
    I dont have any buttons. Only the start button and an on/off switch. The rest is a dial
  • janet_bald May 23, 2009
    I dont have any program lights, only an on/off button with a light and a start button with a light. The program selector is a dial
    Brigadier General:
  • 8,619 Answers
Hi
It means the cycle was interrupted in the middle of the cycle. You'll need to reset the circuit breaker and unplug the dishwasher for 10-20 min.s. If its flashing continously its NTC failure( NTC = Negative Temperature Co-efficient. Basically it's a temperature sensor also known as a feeler. Common problem with Whirlpool machines). Open the underside by removing front inspection panel below door. It's a twist fit probe that fits into the sump. You could try pouring a kettle of boiling water into the sump and trying the machine again. Also take the tech sheet out of the lower kickplate, it would be glued or taped.
Please tell me the model number of your whirlpool dishwasher so that i can provide you with more information.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 23, 2009
  • 527 Answers
Sir,
Try to reset the machine.
1) Turn machine off
2) Press and Keep depressed the power button then immediately press the program button 4 times in quick succession then let go of the power button the first & last program lights will be on
3) press the the program button again to the desired program
4) you can now use it as normal
for more check this link
Thanks
Good Luck
Appreciate to rate as "Fixya"
Posted on May 22, 2009
  • 105 Answers
Hi janet,
the washer may still be in safe mode. try this, reset the unit's memory...
keysequence to reset
heated dry
normal
heated dry
normal
all lights will come on
then close the door
then clean light should go off
if this should not work this sounds like when the heating element cracked and shorted, the surgegoing backward may have taken out the control board. Replacing thecontrol should solve your problem. If you need further assistance,feel free to email us at sales@affordableappliance.com or you can visitour website at http://www.affordableappliance.com Keep in mind we do stock 1000's of Major Home Appliance Parts both New and Good Quality Used.
above all, here are some pointers you may want to look at
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208557727.pdf
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/3976dc6fea92e1c385256fc4006611c9?OpenDocument
hope this helps.
best regards,
ling-IT
Dishwasher does not work - flashing start button
Brandt dishwasher. Code D06 appears!
Jun 17, 2013 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
The start button flashing continuously and the filter area seems to be full of water but when I take it out it is perfectly clean. I have switched the machine on and off several times but each time the...
Please clarify what you mean by "..but when I take it out it is perfectly clean.." are you saying the water in the filter area is clean.
Turn the power off and take out all the water by hand using a small container. Turn the power back on.
If there is no change in the fault, it is likely the flood switch at the base of the dishwasher is triggering and shutting the machine down.
Sep 29, 2010 | Whirlpool Dishwashers
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Clean light flashes and dishwasher wont start
HI, this is a dirty filter alert. it could also be a control fault as well. clean the filter and, disposal as well. if this alert cannot be cleared, replace the control board or, timer.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Whirlpool dishwasher ADP905
Depress start button till start light goes out. Close door, drain pump should run for a while. Wait for end of program, rer-try a new program start. This process is re-setting memory.If this fails to sort problem then start checking components, ie: fill valve water on? heaters open circuit/down to earth, drain pump, is it emptying, wash pump.
Jul 31, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Error code. F14.
Check the motor circulation impeller, if you not maintain the unit is gonna be clog by impeller. it need to be clean.
Jan 11, 2008 | Miele Premier-Plus Built-in Dishwasher
Machine won't start and the START light keeps blinking
A flashing start button shows that the filter is dirty. Remove the filter assembly from the machine. The "tube" can be split into 2 sections fairly simply - do so, and wash each piece under the tap to clean it.
Once the assembly is cleaned properly, select the program that you desire, and press and HOLD the start button for 2 seconds. The wash cycle should begin.
Nov 05, 2007 | Zanussi 24 in. IZZI ALU Built-In...
Dishwashers Logo
110 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
