Question about Acer Iconia A100 Android
How to install memory acer - Acer Iconia A100 Android
I'm trying to reinstall a game on my Acer tablet my daughter did something and she can't remember but it's coming up with failed to extract resources needed b112cpp
it appears the google services app may need resetting (android settings > app manager > google services > clear data) this will reset the tablet's memory of whats installed until the playstore app is opened again if it fails let me know
Apr 16, 2017 | Acer Tablets & eReaders
Acer b1-710 tablet rooted slow streaming what can i configure to increase loading?
You have to increase RAM (random access memory) if it is even possible. A new part has to be installed internally to increase RAM.
Mar 26, 2015 | Acer Iconia B1-710
How I get my memory card on Acer tablet to wok. All that space can't download anything
Your new memory card won't "free up space" until you move stuff from the internal memory to the new card. You can do this with the file manager. The new memory card will show as an alternate location you can move stuff to.
Jan 02, 2015 | Acer Tablets & eReaders
Tablet won't charge
If it's new bring it back on the warantee, if it is out of warantee, check to see if the power supply is putting out the proper voltage at the plug in tip to the Acer. Make sure the tip is put ALL THE WAY into the hole on the acer.
Jan 02, 2013 | Acer Iconia Tab A200 Series Tablet with...
I have an Acer Iconia Tab A500. It is telling me my storage is low. I guess I need a memory card, but what kind...how much storage,etc. Help...I am technology challenged! Lol
Acer Iconia Tab A500 has 16384 MB of Builtin memory. There is a plastic flap right next to the buttons, where you can insert a microSD card.
You can add microSD, microSDHC Card of up to 64 GB MAX
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 08, 2011 | Tablets & eReaders
Can i add windows xp to my acer aspire one
You can install Windows XP to your Acer Aspire provided you have Windows XP installation CD and the product installation code.
Mar 25, 2011 | Acer Tablets & eReaders
Would like to upgrade memory up to 2 Gb, found one slot only . where in the 2nd
There are two memory slots on your computer, one of which is occupied by standard memory. You can upgrade memory by installing a memory module into the available slot.
Installing memory
Follow these steps to install memory:
1Turn off the computer, unplug the AC adapter (if connected) and remove the battery pack. Then turn the computer over to access its base.
2Remove the screw (a) from the memory cover; then lift up and remove the memory cover (b).
50 2 Customizing your computer
3Insert the memory module diagonally into the slot (a), then gently press it down (b) until it clicks into place.
4Replace the memory cover and secure it with the screw.
Jan 08, 2011 | Acer TravelMate C110 Tablet PC
Can't find ram slot!
There are laptops that do not have two slots for RAM. the EEE Pc's for example only have one slot.
Nov 18, 2009 | Acer TravelMate C302XMi Tablet PC
Acer Iconia A100 Android Logo
255 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
