Lg ptac blows warm air - Heating & Cooling
5 Suggested Answers
tborn6
  • 700 Answers
SOURCE: not blowing warm air.
you should probebly have a technician ;look at your unit . if its a heat pump the reversing valve may not be owrking correctly. Also if it is not a hp then the electric heaters may have a bad sequencer and or limit that is not operating properly. Either way the quickest way to get it up and runing would be to call a technician out to repair it. Have a Merry Christmas!
Posted on Dec 23, 2008
flatech
  • 111 Answers
SOURCE: my ptac is blowing out warm air instead of cool
May be low on refrigerant, May want to pull out the unit from the window and see if you see any oil spots anywhere, inside where the coils are at or around the compressor area where copper is located.
If so you will need to call a local Ac company to repair the unit.
Good luck friend.
Posted on Nov 03, 2009
Sparky2012
  • 102 Answers
SOURCE: my ptac is not blowing hot air only blows warm air
freon is low or outside is very cold
Posted on Dec 04, 2009
  • 57 Answers
SOURCE: Have Ptac units that work
I think your PTAC is under charge, if the air filter is clean and the evaporator is also clean together with the blower. Check the freon charge and refill if suction pressure is below 50psi and discharge is below 190 psi.
Posted on Sep 03, 2011
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
PTAC UNIT BLOWING HOT AIR IN COOLING MODE
Hot or warm? Sound like float switch shuts compressor off. Vacuum the drain and clean the pan
Aug 24, 2016 | Heating & Cooling
PTAC is not blowing cold air.
bad switch, bad motor capacitor, bad motor.
Jul 27, 2015 | Amana PTH093E35AXXX
My Amana PTAC set to 90* blows cold air then warm then back to cold. The temperature outside is just a few degrees
sounds like the auxillary heat strips are coming on and off....what kind of time does it cycle on and off?
Feb 16, 2015 | Amana Heating & Cooling
GE PTAC 5500 series cooling and then blowing hot
Cooling gas is missing. Call some AC service in near to fill it, ask more of them for price. Do not switch it on until you solve this to prevent higher damage.
Aug 28, 2014 | Heating & Cooling
Have Ptac units that work fine one minute and 2 hours later just blow warm air.. some that also freeze up the front coils
Sep 03, 2011 | Amana Heating & Cooling
Not blowing warm air.
Nov 16, 2008 | Amana AAC051FRB Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
