Question about AEG Washing Machines
Machine doesn't start washing process
I have an AEG Lavamat 9200 which doesn't want to start - it stays silent at the beginning of any program (doesn't seem to open up for the water - no click...). Advancing the programme manually indicates it is getting power, as the pump starts at designated positions.
Mine fille up with water puttaht is a far as it getes
Posted on May 22, 2009
My aeg lavamat 41070 washing machine doesn`t work at high temperature ( more then 50 degrees) . At low temps it is working OK/
In the case of insufficient heating appears error code E60 what means replace the NTC sensor. Exclude heater, PCB or relay malfunction because you indicate that the machine is heated to 50 degrees Celsius.
Dado
Feb 28, 2015 | AEG Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Aeg lavamat turbo 16830
start at the beginning,, check your fuse
Jul 16, 2013 | Washing Machines
The washing process stops after about 12 minutes at any program and the green door light is on but water in the drum.
it looks like your heating element are dead. But Im not sure.
Does drum is spinning?Does it pumps water then you set in on "drain" program?
Apr 03, 2013 | AEG Washing Machines
My 12 year old AEG OKO LAVAMAT is making a grinding sound when it fills. It's fine at all other times. I've tried cleaning out the filter, and running it empty.
This is usually caused by the recycling pump running empty whilst the washing is still soaking up the initial fill water. as the water begins to soak the clothes it then starts to pass through the drum into the pump and the whole thing quietens down. running empty will not work. to test this theory try opening the drawer very slightly and filling it manually with a hose before starting the machine, (ONLY TO THE NORMAL LEVEL) and see if the noise is still as bad.
Feb 09, 2013 | AEG Washing Machines
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Can I use hot water supply only on my AEG Lavamat W 1159?
A valid point but unfortunately your machine is programmed to take both and will register this as a fault.
This is probably not what you wanted to hear but please dont shoot the messenger.
Jan 22, 2009 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat w1450 electronic.
Try:
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Nov 12, 2007 | AEG Lavamat W1450 Front Load Washer
Washing Machines Logo
241 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
