Question about Acer AL2671W 26 in. LCD Television
Tv service menu - Acer AL2671W 26 in. LCD Television
How can I open the service menu?
Press the helpful button and check link below for various models
First power off your TV using the remote, then press following buttons quickly on your TV remote:
Display (or i+) + 5 + Volume Up + Power
It'll show the hidden service menu on your TV screen.
Once you enter into service menu, you can press Menu (or Options) button again on your remote to switch between various service modes such as Digital, Chassis and VPC.
To navigate between available options press 1 or 4 buttons. To change or modify their values press 3 or 6 buttons.
To save your changes, just press Mute + 0 (or Enter) buttons on the remote.
To restore settings to factory defaults, press 8 + 0 (or Enter) buttons.
PS: For some new models the above mentioned method might not work. You can try following key sequence to access service menu in those new models:
While TV is on, press Left + Right + Mute + Center button + Mute + Menu buttons.
Hidden Secret Service Menu Codes for Sony Samsung LG and Philips TV
TV Service Menus Hidden features you didn know about
Jan 31, 2016 | Televison & Video
Tip
Service menu codes phillips magnavox
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes
# Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
# Turn the TV off to exit the Service Menu
* Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
* Turn the TV off to exit the Service Menu.
* Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
or
* Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
* Turn the TV Off to exit the Service Menu.
* Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
or
* Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
* With the TV off:
Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
To Factory Mode:
Step 1 : Select the source "PC" and then turn off LCD-TV.
Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
Press "menu"button and bring up factory mode indication
on Apr 29, 2015 | Magnavox Televison & Video
Tip
Service menu codes hitachi misc.
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
PROJECTORS :
* Press the {MENU} & {RESET} buttons and then press
the {RESET} button again and hold it for at least 5 seconds.
* The Service Menu will be displayed.
* To exit, turn the Projector Off.
MISC :
1.
* Turn the TV on.
* Press the {MENU} {MENU} {8} {SELECT} buttons on the remote.
* Use the {UP} {DOWN} buttons to select items.
* Use the {LEFT} {RIGHT} to change the data.
* Press the {EXIT} button to exit the Service Menu.
2.
* Turn the TV off.
* Press and hold the {INPUT} button on the TV then press {POWER}.
* Hold both buttons until the TV powers on
with the Service Menu displayed.
3.
* Turn the TV off.
* Press {POWER} & {INPUT} buttons on the TV for more than 3 sec.
* The letter "P" indicates picture and "A" indicates audio.
* Press the {EXIT} key to exit the Service Menu.
on Apr 29, 2015 | Hitachi Office Equipment & Supplies
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
Resetting without going to the menu for a vizio m220nv
Get into the Vizio TV service mode
There are to options to get into Service mode:
Option 1:
Turn the Vizio TV off.
Press and hold the CH + & CH - buttons on the TV.
Then press and release the POWER button on the TV Vizio.
Release the CH+ & CH- buttons.
Now press the MENU button on the remote.
You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This if for factory reset).
Press and hold the MENU button for few seconds.
Option 2:
Turn off th Vizio TV.
Press and hold the CH+ & CH- buttons on the TV Vizio.
Then press and hold the POWER button on the TV.
Keep all three buttons pressed for few seconds.
Feb 18, 2013 | Vizio M220nv 22-inch Full Hd 1080p Led Lcd...
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
TV service menu
press OK on the remote and OK on the TV panel at the same time, after 5 to 10 seconds, the service menu EZ adjust should appear.
another step is to press menu on remote and menu on tv at the same time..
Feb 01, 2010 | Televison & Video
How do i unlock the key--- display on my Provision television that is operated by a beko 12.1 remote control.I also need the service code for some Geometric adjustment.
Service Menu Access Procedure To access the service menu, press and hold the handset sound mute button whilst pressing the TV's front panel 'Menu' button (under the front panel cover on the TV). The up/down channel buttons on the handset step through the options and the left/right buttons change the data values. Turn the TV off to get out of service mode and DO NOT touch any other handset buttons whilst in service mode. Service menu access is also similar for many other Toshiba large-screen TV's so this procedure may work on other Toshiba TV's - even those sold outside the UK.
Maybe this list can help you, click here for a list of each widescreen Toshiba TV Service Menu adjustment with details on the purpose of each.
The factory settings of each service menu option will be entirely different on every TV manufactured, due to component, tube and scan coil tolerances, so don't under any circumstances adjust your TV's settings to my factory default settings or your TV's picture will probably look awful! The factory settings are provided out of interest - the useful part of this document is actually the definition of each service menu option. You will see that some geometry settings are duplicated for each screen mode such as 'Cinema' and 'Subtitle'. This could, for example, help resolve a geometry problem that's present just in one screen mode.
I hope help you with this.
Oct 14, 2009 | Televison & Video
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Oct 21, 2008 | Televison & Video
SERVICE MANU OF MY SANYO KIT
I HAVE A SNYO KIT ( 360 CHANNEL ) USING MICROPROCESOR IC LC863532C-58E2 I WANT TO KNOW THE CODES OF SERVICE MENU & HOW TO UNLOCK TV CHANNEL
May 31, 2008 | Sanyo DS24205 24" TV
Acer AL2671W 26 in. LCD Television Logo
Top Acer Televison & Video Experts
Gareth Cockram
Gareth Cockram
Rommel Balcita
Martin Murray
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
