Question about Lands Phones
Wharfedale IN120 wont stop beeping
Hi all , i've just purchased a wharfedale IN120 and set it up and every 30 seconds or so it lets out a beep , it's driving me nuts, anyone know why before i take it back to the shop ?.
Thanks
I have a wharfedale in120 cordless phone i can ring out but can not get a ring tone in ..... i have tryed everything
Posted on Sep 03, 2009
Hello, did you solve this problem? i just brought one and am having the same problem!!!! HELP
Posted on Nov 16, 2009
    Scholar:
  • 155 Answers
In the settings turn off the call duration reminder
it will work fine
Posted on Jun 04, 2009
My Miele oven has a constant alarm going off every time I try to turn it on, it won't let me set the temperature
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Nov 30, 2016 | Miele Ovens
My tv wont turn on and its beeping
Unplug the set, press power and hold for 60 seconds, let it sit for 30 minutes and plug the TV back in, try to power on, if no change! the problem is power supply or high voltage issue.
Mar 21, 2012 | Televison & Video
First four lights on cycle indicator flash and machine beeps 10 times and then beeps every 30 seconds
I recomend checking drain hose for kinks or obstructions and checking drain pump. most dishwashers will drain first for about 25/30 seconds.Also check the drain hose into the main plumbing connection it maybe blocked.If it cant drain it wont do anything hope this helps.
Feb 17, 2012 | KitchenAid Dishwashers
After baking pizza oven started beeping and hasnt stopped. It says F24 and wont respond to any button commands except for the "oven off" button which just makes it beep faster. What can I do to...
well what i would do is turn off the power to the stove and let it sit for awhile this should reset it. let itset unplug for 30 minutes or so not just a few seconds okay. good luck
Feb 24, 2011 | Ovens
Where can i get a wharfedale in120-3 manual - my
reading unregistered , dont know how to fix it . Has been working
ok previously
Nov 21, 2009 | Lands Phones
Wharfedale IN120-1 How do I record my own answering machine message?
Generally, there is "greeting" key on base, hold serveral seconds untill you hear a "beep" , then begin to record.
Or handset have menu, like "answer machine" ,"Record OGM" like that. record OGM from handset.
Oct 27, 2008 | Philips DECT 2252S Cordless Phone
Wharfedale IN120 beeping
did you ever get it sorted, i just brought the phone and have the same problem!!!!!
Sep 27, 2008 | Lands Phones
I have an Wharfedale IN120 Touch Dectr Phone with Answer Machine, on the answer machine display screen CL is flashing, I don't know why or how to clear it.
I have just posted this to answer someone else but will do it for you in case it comes up elsewhere.You need to key in the time and date again on the handset, because even though it already says the time and date on the handset its because the battery has saved the data but the base needs it re installing to date and time the messages. I unplugged mine to move it and thats when it started flashing it took me ages to work out that CL was the clock. Hope this helps I'm sure it will.
Jun 21, 2008 | Lands Phones
Lands Phones Logo
388 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
