Question about Yard Machines Garden
Fuel lines need replaced
Need help with replacing the fuel lines
  • 41 Answers
The easiest way is to change 1 at a time and watch where it came from, so you can go back with it. 1 should have a filter on the end that goes in the tank.
Posted on May 29, 2009
I need the fuel line routing for an 07 chevy avalanche with 5.3L engine. Which line on the fuel pump is the pressure line? where does it go from pump?
Bruce, look for the fuel line running along frame rail with the gas filter attached, this will be the high pressure fuel line that feeds the engines fuel rail/injectors. searched the net and could not find a lot on the fuel lines for Avalanche. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CK159 259 359 for Chevrolet Avalanche
Pt 1 2007 Chevy Pickup Fuel Pump Replacement At Ray Shop
Pt 2 2007 Chevy Pickup Fuel Pump Replacement At Ray Shop
Aug 19, 2016 | Fuel Pump With Sending Unit Chevy...
Location for fuel line on a 2006 ford explorer xlt 4.0 shoc
Geronimo, Normally the fuel lines run from gas tank, along frame rail, then up to fuel rail into injectors.
2006 ford explorer xlt fuel line routing Google Search
Ford Fuel Filter Replacement Change How to Do it yourself
Fuel Filter Replacement 2006 Explorer
Fuel pump replacement Ford Explorer 2005 2010 Install Remove Replace...
Mar 04, 2016 | 2006 Ford Explorer XLT
1989 f250 460 engine fuel problem
if the fuel lines have any rubber fuel lines they could be sucking air. also try replacing the fuel caps, it may not be venting
Dec 02, 2013 | 1989 Ford F 250
Fuel line on MAC 3516 is broken. Where to get the new one and the fuel filter? How to replace the fuel line?
Hi szeldovich
You can pick up fuel line at any small engine shop/supply house.
One trick to insert the fuel line into the tank is to fold it the end to make it smaller than the hole in the tank...also put a little wd40 or vaseline on it to make it easy to pull/push.
Always insert more fuel line into the tank than is needed, as you have to reinsert the fuel filter back into the line and pull it into the tank again.
Here is a picture of how to route the fuel lines.
Please take time to rate me
Bud
Oct 17, 2012 | McCulloch Garden
Where is a 1989 nissan z24 4 wheel drive fuel regulator located? starter went bad, replaced it, fuel line had a leak, replaced it, fuel pump wont push fuel through it, bought a new one and now the truck...
Fuel reg. is connected to the fuel rail where the return line is connected, my thoughts are you mentioned air in your lines.. crack open fuel lines and run fuel pump to release air from lines. Pump then should prime all lines must be primed turn engine over to release air ( No Smoking) then tighten lines. fuel rail might have valve, (looks like tire valve) if so it is recommended that air is relieved at air valve
Mar 21, 2011 | 1989 Nissan Hardbody King
Need to replace fuel lines on my Troy Bilt gas hedge trimmer. Where can I get replacement fuel lines... or better yet... what size are the lines and where can I buy a few feet of the lines. Note: I...
Replacement fuel lines should be readily available at your local lawnmower repair shop. Your TroyBilt hedger uses fuel line that is 3/32" (2.4mm) interior dimension, 3/16" (4.8mm) outside dimension, with a 3/64" (1.2mm) wall dimension.
Most manufacturers don't offer replacement line, only fuel tank assemblies. Find your local shop, and try to get the TYGON brand...it is yellow. Tygon lasts the longest. You should be able to buy it by the foot for less than $2 per foot. You will need 2 feet of hose to replace both lines.
Make sure to clean the in-tank filter when replacing hoses.
Good luck.
Oct 20, 2010 | Craftsman 22" Gas Hedge Trimmer
Should I leave a small peice of fuel line in the gas tank ?
Hi and welcome to FixYa, I am Kelly.
Ok.. We need your help here. I understand your going to replace a fuel line. Depending on what make and model your doing the fuel line replacement on the procedures are different. Some connect to the tank outlet. Some connect to the fuel tank screen pick up
others connect to a fuel shut off valve. They all end at the carburetor.
If you do a like part replacement the only thing you have to be concerned with is that it does not leak after you install the new line. What is most important is that you make sure to clamp both connecting ends of the new line. Fuel lines rapidly get hard and will leak causing the possibility of a fire during use / personal injury. I have repaired numerous BURNED units that early in the mowing season the owner had replaced the fuel line and by July or August it caught fire because they did not install the clamps or the right clamp when they replaced the fuel line. It isn't a difficult task.
Thanks for using FixYa.
Kelly
(If you need more details I need a make and Model number to be of any further assistance to you.)
Mar 30, 2010 | Garden
Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Jun 21, 2009 | Garden
1996 Audi A6 2.0 fuel line leak
Is the line leaking a metal line or "hose" line. You really should replace the line...USE FLARE NUT wrenches ONLY...!!!!!
A metal line can be spliced using copper line, a flare tool, compression flare fittings,etc.. A good mechanic will be able to help.
Any leaking fuel line should be replaced... ,, USE FLARE NUT wrenches ONLY...
Jun 25, 2017 | 1996 Audi A6
Garden Logo
97 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
