Question about Dell Inspiron E1505 Notebook
Dell Inspiron 1505; Battery does not charge; DC jack is loose..
I have a Dell Inspiron 1505. It works when connected to A/C power outlet, but has a loose connection in DC jack. The adaptor needs to be pressed upward. But it does not charge when connected. I bought a new battery pack in Feb 2008 from Dell. So I cant believe that the battery is bad. How do I know what to replace? DC Jack or battery? Is there a problem with charging function? Any help is appreciated. I have the exact same problem. The computer does not register that it is plugged in, when it is. Either way can you suggest a company that would be able to fix it in Albuquerque NM?
  • Dell Master
  • 32,281 Answers
You have either a faulty connector plug on the power adapter which connects into the laptop or the loose power input socket on the laptop is faulty. This is because you need to press the connector upwards to make electrical contact.
Test the connectot plug on the power adapter with a multi-meter, wriggle the connector to see if your get the voltage to fluctuate, if it does not then the connector is OK anf the fault is in the laptop power input socket.
If the fault is in the power adapter plug or the laptop's power input socket, this can be repaired, a techo would have no trouble in repairing these faults.
Posted on May 22, 2009
Dell inspiron "plugged in not charging"
There are some troubleshooting steps for this sort of problem:
laptop plugged in not charging:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure your dell inspiron 1545 power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Jan 14, 2013 | Dell Inspiron 15 Laptop
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
Charging light is flashing
There are two possible causes for this issue:
1) Your dell 9400 charger is malfunction
2) Your laptop dc power jack is loose or dead
Possible troubleshooting step:
1) Borrow a compatible dell charger to plug in your laptop, if it works without any issue, it means your dell inspiron 9400 adapter need to be replaced.
2) If the compatible dell 9400 charger won't work normally, the problem may lie in your dc power jack.
Hope this will help.
Jan 07, 2013 | Dell Inspiron 9400 Notebook
Won't charge, purchased new battery and new AC adapter, still does not charge. AC charges other Dell I have so must be in charging circuit or connector. How do I disassembly computer to voltage getting to...
You are right, most of the situations like this end up that the charging connector fixed / soldered to the motherboard get damaged because of shaking the connector when ever we connect and disconnect it .
Mar 06, 2011 | Dell Inspiron 2600 Notebook
Dell 910 mini will not recognise any battery and will not recharge
You may have a loose DC jack:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 23, 2011 | Dell Inspiron Mini 10 Notebook
Dell inspiron 1420 not recognizing ac adapter
One possibility is that the power cord attaching the power adapter to the DC jack in the laptop might be broken or damaged. Inspect it visually to verify this possibility.
Also, try measuring the DC output from the power adapter's outlet to make sure it is providing the correct output voltage needed to run the laptop (if at all).
Another possibility is that the DC jack where the power adapter connects to the laptop might be either loose or damaged, & needs to be either re-soldered or replaced. However, in order to do this, you will need to disassemble the laptop & get the motherboard out.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 03, 2010 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
My dell inspiron 1420 dont charge. the indicator in the taskbar does not indicate that it is charging if it is plugged in
Either you got a faulty AC adapter or there is a problem with the DC power section of the Inspiron (or maybe the DC jack). Usually it's the adapter. You can check it with any commercial multimeter: it should give you 19V with internal positive. If it's broken, most Dell use the same adapter and it's easy to find cheap deals on eBay, for example.
Unfortunately, if it does work, and yet the notebook is NOT working if you take out the battery and plug the AC adapter only, you'll probably have to call Dell tech support.
Dec 05, 2009 | Dell Inspiron 1420 Laptop
Dell inspiron 9300 doesn't charges i doubt its dc jack is broken , wanna fix it
If it works from DC jack try to change the battery first, for example to the same battery from another comp. If DC jack is broken and laptop don't works from wall outlet better change the jack in service center. Disassembling Dell is hard work... Cheers.
Sep 20, 2009 | Dell Inspiron 9300 Notebook
The loose connection for the AC adapter means the motherboard needs to be replaced or the AC adapter jack on the motherboard needs to be replaced. (With Labor, it is about the same cost to buy a new motherboard as it is to have the old one fixed)
Motherboards are available on EBay for around $100
Apr 25, 2009 | Dell Inspiron E1705 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron E1505 Notebook Logo
619 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
