Question about Bosch Dishwashers
I have a Bosh clasixx dishwasher, the drain pump keeps running all the time even when the sump is as dry as it gets and even with the door open??? Paul
When water is in the sump the pump drains it quickly.
TJBENGR
  • 121 Answers
SOURCE: Dishwater won't stop trying to drain even when door is opened
The drain valve is stuck open. This is electrically operated, but may have some debris inhibiting movement. If you can physically move it (with the power off) this should repair the problem.
Posted on Apr 21, 2008
  • 3 Answers
SOURCE: Bosch Dishwasher SHV4313GB/17 Wont switch off !
Introduction: This may work for your problem, but only if you're finding that you cannot get further water to flow into your machine. If your machine fills OK, then this ISN'T a solution to your problem. If your machine doesn't fill but your drain motor continues to hum for no apparent purpose, this may work.
I have a Bosch SHV. My sink drain backed up, and the water accumulating in the sink then migrated to the dishwasher, through the drain pipe, causing the dishwasher to fill up and, it turned out, overflow a little. When I turned on the dishwasher, the water drained, but no new, clean water came through the hot water pipe. The drain just kept running, but nothing else happened.
Here's what happened. Under the main chamber of the dishwasher, by three inches or more, is a white plastic tray. It sits almost at the floor, and it may not be obvious that it's a tray capable of holding water. The overflow water spilled into that tray, which in turn caused a float in the far left side of the tray to lift (the way a toilet float lifts when the water fills in a toilet tank) and shut off the water intake valve (like the toilet float shuts off the toilet water flow). So long as that valve is closed, your machine will not run.
STOP: disconnect power supply at this point for safety.
To see the white plastic tray and thereby fix the problem, you'll need to take off the BLACK TOE-KICK (attached on my unit by two star-head screws at its bottom) and, possibly , the OUTER PANEL OF THE DISHWASHER DOOR (in my case, a custom wood panel (attached by a few screws through the inner side of the door, two screws that are accessed by popping off little--smaller than a dime size--covers on the sides of the doors, and then the door panel lifts up and out). (I took the outer panel off, but I can't remember if I would have had to reach into the white tray without doing so.)
Once you do that, you can see the white plastic tray. It doesn't come out--at least not without removing the entire machine--so try this. You can take your fingers and feel over and into the tray. You'll probably feel the water--I did. Look at the far left of the tray with a flashlight. Back there you'll see a flat, round, 3-inch diameter piece of white plastic sitting at the bottom of the tray. To its center is a generally U-shaped lever looking device, which, at its far left end, is connected to a red stick pointing up into the machine. When water goes into the tray, the float rises, causing the U-shaped lever to rise, causing the red stick to raise, which (though I couldn't see it) causes an electrical signal to run to, and shut, the valve for your water intake.
I took paper towels, and then a narrowly cut sponge, to sop up the water in the tray. I then took my shop vac and, using it as a blower, blew what little water was left right out. You might be able to use a hair dryer, but first sop out what you can or it'll take forever. Once you've done that, put everything back together and plug your dishwasher back in. My buttons are at the top panel. To reset, hold down the two buttons marked for clear drain for three seconds and release. You should be able to start up then. It took 15 seconds before the water started to run, but it did and the machine works fine again.
Interesting note: The valve that stopped the water from flowing in automatically opened once I got the water out of the tray. You don't need to reset the valve.
Good luck.
Montpelier Man
Posted on May 09, 2009
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
Macmarkus
  • 2605 Answers
SOURCE: Bosh dishwasher SHU43C05UC won't
Welcome to FixYa.
Based on your description " won\'t finish the cycle. won\'t drain and keeps running for ever when gets to 1 min left.Hoses checked and not clogged. I was able to drain the water by doing the test run and punching the rinse and hold button"
I'd say the issue is most likely with the control...unfortunately. The "1" being displayed is actually an error code associated with a heating fault.
Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described.
**B/S/H/ also issued a recall on certain models between 1999 - 2006 depending on the model & serial number, and it does apply to yours....based on just the model number, but check the serial number. It applies to serial numbers betweenFD7905 - FD8505 The issue was directly related to the heating circuit (specifically the heat relay on the control) Here`s the link if you want to see for yourself **
http://microsites.boschappliances.com/safetyrecall/dishwasher/
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be contacting Bosch re: the recall or calling in an authorized bosch service tech. if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...or takes a long time as I mentioned and eventually display's "1" on units with a display.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further. I would recommend you contact Bosch regarding this recall, perhaps the repair will be free...but I don't speak for them.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Nov 15, 2010
SOURCE: We have a neff dishwasher and the pump is draining
Hi there, our neff S54T09 doesn't seem to want to fill with water, it starts to fill for about 5 seconds then stops, then stops & starts filling for about 10 seconds then stops completely & nothing happens!! Have checked the water inlet & its filter & they are ok.
any idears Regards Peter
Posted on Apr 06, 2011
My bosh dishwasher beeped,showed a code of "24" said "watertap" and stopped working. What does that mean and what do I do now?
I would normally say it sounds like a water supply issue (solenoid etc), but have heard elsewhere that the issue is possibly linked to drainage. Does your Machine drain? Try emptying it out and refilling with hot water straight into the wash tank sump. Leave for a few minutes then run through a drain. After a few times this should clear any grease build up. If not draining at all after this then look for a solid blockage in the drain pipework or pump?
Nov 02, 2017 | Dishwashers
Edgestar DWP60ES prematurely ending wash cycle, will not drain properly, beeps alot
most likely the dishwasher has a minor leak in the base under the wash sump. this could be tripping the flood switch which causes the pump to run continuously. when the leak dries up you are able to start normally until the leak trips the flood switch once again.
Check for leaky door seal or hose. see edgestar site for instructions on getting to the area under the sump. make sure dishwasher is disconnected from mains when working on it.
Jul 25, 2012 | Dishwashers
Won't clean-looks to run properly
check the sump area below the pump and clean out any waste food debris,etc. and also the drain check valve,it may be plugged and not draining waste water completely or not closing completely and letting waste water back into the sump and this could be getting back through the pump and sprayed back onto your dishes
Jul 28, 2010 | Kenmore Dishwashers
Drain pump won't turn off
The reason the drain pump continously runs is because it is trying to remove any water too avoid any further flood as there is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Hope this helps.
Jan 24, 2010 | Bosch Dishwashers
Dishwasher pump keeps running
This is caused by a water leak into the base pan,it will trigger the anti flood and the machine will continously drain out even with the door open,you need to establish what is leaking,if you leave the appliance standing for a few days it will start again as the water will evaporate however if the fault returns you will definetly have aleak on the appliance which will require further investigation.
Jul 29, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Bosch Clasixx dishwasher sticks at point when it drains water
you have a clog remove the float clean and replacs,sould work now.
Jul 15, 2009 | Bosch 24 in. SGS43C12 Classixx...
Neff dishwasher s5433xogb/29 pump keeps running
Our Neff Dishwasher S5456X0 the pump was running all the time and the solution 1 worked. We removed the front panel under the door and the the flood camber was full of water. Drained it out with a sponge and the dishwasher is fine. Thanks
Nov 20, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Bosch SGV43A03 DISHWASHER: pump drains all the time, even if reset!
Typically you could possibly have a leak in the base or sump which activates a little float switch. This in turn switches the drain pump on continuously and deactivates the programing cycle.Sort out the leak.
Feb 24, 2008 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Beko Freestanding Dishwasher
Hi there ....this condition is ususally caused by a water leak into the sump of the dishwasher which activates a safety switch to run the drain pump..preventing the appliance from being used....Remedy...tip the dishwasher back in the head allowing excess water to exit from the sump...then with the door open check that the air vent lock ring is secure, thet the salt unit retaining ring is secure..and finally that the filter unit to base screws are secure...this done re-start and you should b fine
Jun 28, 2006 | Beko 24 in. D3731F Free-standing...
Dishwashers Logo
15 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
