Question about Panasonic KX-TG4771 DECT 6.0 Expandable Digital Cordless Answering System Corded Base and 1 Cordless
Base no power
The unit screen dont show a thing
My LG dishwasher shows a faukt, EI is this the same as LE
that fault means there is a leak in the dishwasher and the water is setting off the flood switch in the base of the unit, if you pull the unit out from its cavity and tilt it backwards (not forwards) on a sharp angle you should get a big puddle of water run out of the base which means something is leaking inside the dishwasher and will require further investigating, if you dont get any water run out the problem will be that the motor is overheating and will need to be replaced (dont ask me why this error can mean two completely different things, i guess they felt like giving us a challenge)
Jan 17, 2017 | LG Dishwashers
Phone are 5.8 ghz vtech
may be the frequency problem for noise problem.
pleaSE CHECK IT OUT.
ADJUST THEM AT SOME PROPER LEVEL..
AND THEN TRY.
Oct 18, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
The photo slide show is now blank The photo show is now blank. I have a GE model 27956 DECT6.0 Cordless Handset with Caller ID & Slide Show. I can not view or add new photos to the slideshow. I pushed...
Welcome to Fixya
Try this procedure to drain the static energy of the phone.
1. unplug power from base
2. unplug phone connection from base
3. remove cover and battery from handset
4. wait 10 minutes
5. put battery back, reattach phone connection and power
Thank you for using Fixya!
Jul 22, 2011 | GE Lands Phones
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
Phone Not Working
Remove the battery from the back, wait 1 minute, then replace the battery. DO NOT HIT ANY BUTTONS. place the phone back on the main base unit so it can reregister.
Apr 09, 2010 | Uniden DECT 6.0 Cordless Phone ID
Uniden 5.8ghz cordless W/2handsets has no dial tone cannot call out or recieve calls
There can be a lot of different things that could cause this. The first thing I would do is disconnect the telephone cord from the Uniden phon eand connect it to another telephone and see if you get a dial tone from it. If you do then we know that the telephon eline and the cord are OK so we go back to the Uniden telephone. Next, does the unit light up when you plug it in? are you sure that the telephone is getting AC Power? Are the displays on the handsets working? Does the handset display show "Handset XX" or does it show "Searching"? If it shows "Handset XX" then the base unit is getting power, if not the base unit may not be getting power.
If the base unit is getting power and the handsets are working and the power cord and jack were proven good by conecting another phone to them, then you would need to call uniden Customer Service for further trouble shooting or repair/replacement. the number is 1-800-297-1026
Jan 26, 2010 | Uniden Cordless Phone
Phone on base showing it is "searching" for base.
check to see if the power cord is properly plugged in. You may have the phones on the wrong cradles, this wil cause them to search.
Apr 29, 2009 | Uniden Cordless Phone
Info
Is the power light on? If not, recicle the monitor. If it is on, then maybe the back lighting is the culprit.
I have a similar problem, and the repair is more expendive than buying a new one.
Sep 18, 2008 | HP vs15 15"LCD Flat Panel Monitor
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
Viewsonic E53 monitor
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Dec 06, 2007 | ViewSonic G90fb 19" CRT Monitor
Panasonic KX-TG4771 DECT 6.0 Expandable Digital Cordless Answering System Corded Base and 1 Cordless Logo
35 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
