Question about General Electric WBVH5200J Front Load Washer
Washer will lock and rotate 3 times then back 3 times then unlock
  • 1 more comment
  • Rob Blake
    Rob Blake Jan 05, 2014
    I have conducted all test on machine WCVH6800J1WW. T05 appears to be working fine, as does T06 and T07, T08 does not activate the water value. T09 does not activate the water value. I have replaced the water valve, no luck. Check Pressure hose, no holes or leaks. Need ideas please..
  • Rob Blake
    I have just check T06 again and it only will perform the Empty test; it does not fill the tank with water and test the various levels.
  • Rob Blake
    I have executed test T06 again and it works great! Did not realize that I had to press the Start button repeatedly to ensure all test levels were reached. I have a copy of the Wiring Diagram 175D5412P002 and noticed the Test T08 (water valve Hot) and T09 (water valve Cold) are not listed; have they been removed from the testing code?
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
How to manually open locked door
First UNPLUG the WASHER.
There is a little white circle plastic lever that feels like an upside down lollipop about 2-3 inches below the door lock behind the front panel.. Pulling that down will unlock the door.
To access from the top of the washer remove 3 screws to the back top of the washer, push it back and then lift the top off the washer. Facing the washer slide your right hand down the space at the front corner where the lock is located. Feel around for the circular part at the bottom of the door lock and gently push it down. The door should then manually click and unlock.
To access from the bottom of the washer. Facing the washer, Remove the 3 screw to the very bottom that is holding the small access panel in place. This allows access to the bottom of the washer. Once removed, reach towards front and upwards to where the door lock is located. Feel around for a circle plastic level. Pull the level down. The door should click and you should be able to open the door.
Apr 18, 2014 | Maytag Washing Machines
Envoy hatch lock
There is a known TSB for this....
#07-08-52-003: Rear Liftgate Glass May Not Lock When Using Remote Keyless Entry (RKE)/Key Fob Transmitter/Door Lock Switch, Lifgtate Hatch or Liftgate Glass May Lock/Unlock When Rear Liftgate Glass Button Depressed - (Sep 13, 2007)
Subject: Rear Liftgate Glass May Not Lock When Using Remote Keyless Entry (RKE), Key Fob Transmitter or Door Lock Switch, And/Or Liftgate Hatch Or Liftgate Glass May Lock Then Unlock When Rear Liftgate Glass Button is Depressed (Reposition Lock Cylinder Wave Washer and Adjust Lock Rod)
Models: 2005-2007 Buick Rainier
2005-2008 Chevrolet TrailBlazer, TrailBlazer EXT, TrailBlazer SS
2005-2008 GMC Envoy, Envoy XL, Envoy Denali
2005-2008 Saab 9-7X
Do This
Don't Do This
Reposition liftgate lock cylinder wave washer and adjust lock rod.
DO NOT replace the liftgate latch or actuator.
Condition
Some customers may comment on one or more of the following conditions:
• The rear liftgate glass may not lock when using the remote keyless entry (RKE), key fob transmitter or door lock switch unless the lock is pressed a second time.
• The rear liftgate or glass locks, but may be unlocked when the rear liftgate lock cylinder button is depressed.
• The rear liftgate locks but the liftgate glass may not lock.
Cause
These conditions may be caused by one or all of the following:
• The rear liftgate cylinder lock rod may be out of adjustment.
• The wave washer on the liftgate lock cylinder may be out of position with the cup side down.
• Excessive movement or slack in the lock rods at the liftgate bell crank assembly.
• The liftgate lock cylinder pawl may contact the rear liftgate glass latch when the lock cylinder button is depressed.
Correction
Important: Do Not remove the rear liftgate lock cylinder from the vehicle to perform this repair.
Reposition the rear liftgate lock cylinder wave washer and adjust the lock rod using the steps below.
Verify the customer's condition.
Open the liftgate.
Remove the upper liftgate garnish molding.
Remove the rear liftgate trim panel.
Remove the cylinder lock rod from the threaded lock rod retaining clip.
Tip
Place the tip of a screwdriver blade into the opening of the C-clip and slowly rotate the screwdriver to pry out the C-clip from the shaft. Then use needle-nose pliers to remove the C-clip.
Remove the C-clip from the rear liftgate lock cylinder push button and remove the wave washer.
Install the wave washer with the cup side up.
Position the wave washer with the curved edges of the wave spring parallel to the tabs on the lock cylinder shaft.
Important: Use needle-nose pliers to slightly squeeze the C-clip back into shape. Make sure the clip seated, you should feel a snap and hear an audible click.
Install the C-clip onto the shaft and in the slot using needle nose pliers. Then rotate the pawl several times to make sure the C-clip does not rotate. If the clip rotates then the clip is not fully seated.
Position the lock cylinder pawl to the full clockwise position.
Pull up on the cylinder lock rod to remove any slack in the bell crank.
Install the cylinder lock rod into the threaded lock rod retaining clip while removing any slack from the lock rod linkage.
Close the lock rod retainer clip.
Close the liftgate assembly.
Open the liftgate glass while keeping the liftgate closed.
Use the key fob to cycle the liftgate to the lock and unlock position while inspecting the rear liftgate pawl. The lock cylinder pawl should have clearance between the latch as shown above. If the pawl is contacting the latch, readjust the cylinder lock rod.
Verify that the customer's condition has been corrected.
Install the rear liftgate trim panel.
Install the upper liftgate garnish molding.
Apr 14, 2014 | GMC Envoy XL Cars & Trucks
Rear liftglass won't lock
2005-2008 Saab 9-7X
Do This
Don't Do This
Condition
Cause
Correction
Open the liftgate.
Tip
Jan 17, 2012 | 2009 Saab 9-7X
We own a 2000 Pontiac Grand AM, 3.4 liter, 2 door coupe with front wheel drive and recently replaced the transmission and now can't find our key set. Great start We hired a local Lock Smith who...
You can purchase new Remote Keyless Entry (RKE) transmitters from the dealer or you can order them online at the web sites listed below or several others. Your vehicle provides for programming the RKE transmitters without the use of a scan tool. Follow the instructions below.
2000 PONTIAC GRAND AM RKE TRANSMITTER PROGRAMMING
WITHOUT A SCAN TOOL
1. Close all vehicle doors. Remove key from ignition lock cylinder
NOTE: STEPS 2 AND 3 MUST BE COMPLETED WITHIN 25 SECONDS OF PRESSING THE DOOR UNLOCK SWITCH
2. Press and hold door UNLOCK switch. While holding UNLOCK switch, insert and remove the key in the ignition lock cylinder twice. Do not rotate the lock cylinder.
3. Insert the key a third time, leaving the key in the lock cylinder. Keep the lock cylinder in the LOCK position for the remainder of the procedure. Release the door UNLOCK switch. The chime will sound 3 times to signal that the programming/diagnostic mode is active.
4. Press and hold LOCK and UNLOCK at the same time on the RKE transmitter for approximately 4 seconds. The chime will sound 2 times signaling that the transmitter has been programmed.
5. Repeat step 4 for each transmitter being programmed. (You can program up to 4 transmitters.)
6. To exit program mode, turn the key to the RUN position then back to the LOCK position and remove the key. Your transmitters should now work to lock and unlock your doors.
2000 Pontiac Grand Am Transponder (direct links)
- autotransponder.com
-keylessremotes.com
-ikeyless.com
Jun 10, 2011 | Pontiac Grand Am Cars & Trucks
I get an F11 error. Washer will not start in any mode.
GHW9150P Tech sheet:
FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
-Verify inlet valve operation.
If there is water in the unit:
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
F-5 Water temp sensor failure
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the "F/05" error code
will be displayed. Possible cause/proceedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Refer to the
"Water Temperature Sensor" section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
F-06 Drive motor Tachometer error
Possible causes/procedure:
1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
F-07 Motor control unit error
Possible causes/proceedure:
2. Check wire harness connections between the drive motor and
3. Plug in washer or reconnect power.
4. Check the MCU by looking for operations of the drive motor.
5. Check the drive motor for powered rotations.
F-09 Overflow Condition
or kinked.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. the pressure switch for proper operation.
F10 Motor control unit heat sink thermal trip
1. Check for proper installation, verify the unit is not located
near a source of heat and has proper ventilation.
3. Check wire harness connections to the MCU, the motor,
4. Check the drive system for any worn or failed components.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
2. Check wire harness connections to the MCU, the motor, and
3. Check the drive system for any worn or failed components.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
F13 Dispenser circuit error
2. Check mechanical linkage from dispenser motor to the top of
the dispenser.
3. Check wire harness connections to the dispenser motor and
4. Check dispenser motor for powered rotations.
F14 The dreaded EEPROM error
The Central Control Unit (CCU) receives its data from an EEPROM
onboard the CCU. If there is an error reading this data it will cause this
error. Possible causes/proceedure:
¦ A power glitch may cause this error.
1. Unplug washer or disconnect power for two minutes.
2. Verify CCU operation by running a Diagnostic test or any
cycle.
F15 Motor control unit error
If the MCU detects multiple resets or errors during a wash cycle it will
go into this error mode. Possible causes/proceedure:
3. Check drive belt.
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
touch-pad/LED assembly and Central Control Unit (CCU).
F du Door unlock error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to
unlock the door 6 times before displaying the error code.
¦ Door lock mechanism is broken.
¦ Door switch/lock unit failure.
1. Check door switch/lock unit for foreign objects.
3. Check wire harness connections to the door switch/lock
unit and Central Control Unit (CCU).
NOTE: The door switch/lock unit can be manually unlocked. See
"Manually Unlocking The Door Lock System".
F dl Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
¦ Door lock mechanism is broken or removed from door.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Sud: Suds lock (overdose of detergent detected during wash cycle)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
¦ If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
or kinked.
6. Check drain pump.
7. Check the pressure switch.
cycle.
Tech sheet link:
https://servicematters.com/secured/docs/wiring/Tech%20Sheet%20-%208182277.pdf
Mar 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
07f error code... duet washer W9150
Tech sheet on this model:
on all the way.
the inlet valves.
F-2 Long Drain
display.
or kinked.
or kinked.
cycle.
MCU connectors.
the dispenser.
cycle.
or kinked.
cycle.
Tech sheet link:
Jan 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
This is the second time this problem has occurred. The machine simply won't fill. The door locks and then nothing. Last time it resolved itself after about 4 hours. This time it's been overnight and...
You could check your inlet hoses for kinks You inlet screens on the valves for clogs.themobilian_473.jpgthemobilian_474.jpgall this stuff you can do a filter clean out as shown HERE
Your tech sheet info:
on all the way.
the inlet valves.
F-2 Long Drain
display.
or kinked.
or kinked.
cycle.
MCU connectors.
the dispenser.
cycle.
or kinked.
cycle.
Tech sheet link:
Dec 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My 4 year old high efficiency front load washer set code "LE" (Overload in Motor). I unplugged and plugged back in and set to quick rinse and spin. Washer started adding water and trying to balance itself....
LE
LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY. • The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable. • The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited). • The hall sensor is out of order/defective.
Jun 23, 2009 | LG WM-2277HW Front Load Washer
Washer starts then stops and displays f28
hello southerndav4,
Welcome,
you said, you when the unit is started in any cycle it will lock the door and then run water in for a couple of seconds. It then stops the water and unlocks and immediately locks again. There is no further action except the timer counting down until f-28 code. There is no tub rotation and the ccu was replaced.
I see you did a couple of tests and replaced the CCU!!
You did do what I would have suggested.
You may need to use hands on service this time!
rather than swapping out expensive parts blindly!
Let me know...
Huum
Please remember to leave a rating
This is the condition fo the F28 error code
SERIAL COMMUNICATION ERROR
The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
This is what you need to check and or repair
2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU).
Check connections of the CCU board within the housing.
Make sure all grounding switches are engaged.
5. Verify CCU operation by running a Diagnostic Test or any cycle.
8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
Sep 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
General Electric WBVH5200J Front Load Washer Logo
Top General Washing Machines Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a General Washing Machine Expert? Answer questions, earn points and help others
