Phim cap 3 nhut - Computers & Internet
2 Suggested Answers
bigsteve474
  • 1087 Answers
SOURCE: phim cap 3
There seem to be quite a few people with problems here on YouTube.
Many YouTube videos will play using HTML5 in supported browsers. You can request that the HTML5 player be used when possible.
If you encounter any problems, right click on the player and choose "report playback issue",
Posted on Feb 08, 2014
What pressure is the radiator cap on this car with 350 V8 motor thanks Mike
3 different p.s.i caps for 3 different types of radiators,typically radiator are classed in core depth (how many row,s of tubes are visible in the top tank) normally system pressure is about 12 p.s.i for a 3 core radiator cap (automobile) if cap is constantly leaking coolant,inspect the seal inside cap,if seal is undamaged pressure spring has lost its trntion dispose of cap in appropriate manner...
Jul 13, 2015 | Cars & Trucks
Phim lau xanh
Please use Google Translate to ask questions in English
Suitable sites for Xanh? Depends what country you are in
May 21, 2014 | Computers & Internet
Phim cap 3
Feb 07, 2014 | Computers & Internet
Xem phim cap 3
English language please.
Feb 01, 2014 | Computers & Internet
Phim cap 3
Which capacitor?
Nov 21, 2013 | Computers & Internet
Phim cap 3
Not sure what you mean. Please explain.
Nov 07, 2013 | Computers & Internet
Trouble code p0449
This is a fuel vapor leak code, check the gas cap. Pull off cap and reseal the cap and make sure you turn the cap 3 times so total rotation of the cap equals one full turn.. The code should go away after 3 starts to full heat and run condition.
Apr 22, 2013 | 2006 Pontiac G6
2001 dodge ram 1500 5.2 v8 van spark plug diagram
firing order is 1 8 4 3 6 5 7 2 standing in front of truck. cylinders on passenger side facing you are 2 4 6 8 cylinders on driver side facing you are 1 3 5 7 now this is your spark plugs wires location on distributor cap.with distributor facing you.2 plugs wire on cap 6 oclock position 1 plug wire on cap 8 oclock position,8 plug wire on cap 9 oclock position,4plug wire cap 10 oclock position,3 plug wire on cap 12 oclock position,6 plug wire on cap 1 oclock position, 5 plug wire on cap 3 oclock position, and 7 plug wire on cap 5 oclock position. in order for this to work you must be standing facing the engine all plug wire location on cap should be correct.
Apr 08, 2011 | Dodge Ram 1500 Cars & Trucks
Power Supply
I fixed my Akai LCT3201AD in about 30mins. using 3 small parts from Radio Shack. Once I got the back off, I found the power supply board (PSB), mine was part# MLT-169B rev1.2. I looked at the capacitors (caps.) first, because they are usually easy to diagnose. I noticed the caps. bubbled out on the top of the board (where all the cables connect to it). There is 3 of them in a row, positioned between the two large heatsinks. My guess is that the heatsinks are generating a LOT of heat over time, because of bad ventilation, and causing the caps. to fail.
I went to Radio Shack and found 3 caps. (only had 3 in stock). The original ones were 16V-1000uF, Radio Shack only carried 35V and 50V in the 1000uF caps., so I bought the 35V ones and headed home, I removed the old caps. from the board, and installed the new ones. The 35V caps, are a little bigger, so its a tighter fit on the board, be careful. It took longer to remove the back from the TV than it did to do the soldering. YouTube.com has excellent videos on how to de-solder caps. on PSB's.
Total money spent on repairs:
$1.59 ea for 3 Caps. (part# 272-1032) $4.77
$2.99 for new soldering iron tip + $2.99
$1.00 donation for St. Jude's + $1.00
Total including tax $9.30
So for less than $10, I did a repair that my local TV repair shop wanted $575 for. Online stores want anywhere from $100-$275 for a PSB. If I get another 2 yrs out of it that's well worth $10.
Dec 29, 2008 | Akai LCT3201AD 32 in. LCD Television
Computers & Internet Logo
David Payne
David Payne
