Pc 2008r usb plug - Computers & Internet
What to do when your alienware m14x does not read USB flash drives?
good day have you been tried to plug the usb flash drive with other usb input of your pc or tried to plug with other pc just to ensure where the problem. if still doesn't read using with other pc that was mean your usb drive might have problem. if the case that your usb drive work with other pc the problem is with in usb jack which need to check weather loose wiring or software problem.
May 18, 2014 | Computers & Internet
When i plug in my usb web cam into my pc, nothing at all happens or pops up. what do i do?
the pc could not recognize your web cam, try to plug out your usb web cam and blow or wipe the usb of your usb webcam. also try to plug it in to other usb port of your pc. if nothing happens, maybe the web cam it is the problem. and just to make sure that the web cam your using is the problem, try other usb web cam to see if its working on your pc. if the other web cam works on your pc, the web cam your using is damage, and if the other webcam is also not working, the usb ports of your computer is the problem.
thank you for choosig fixya. if you have other question regarding to this problem, just post it.
Jan 14, 2012 | Logitech Computers & Internet
How to connect nokia 6300 in pc via USB
heya !
Before you plug your phone to your PC install the Nokia PC suite from here OR ovi from here. It 's usefull to save the contacts datas and other things to your PC, or to synchronise PC and Phone.
1 . You need to have a USB/mini-USB Cable to do that.
you can find it here for exemple.
2 . you have to plug the Mini-USB into your phone here
3 . the other part of the USB Cable go into your PC.
When you plug the phone to your PC you will have to choose the mode of conectivity you need to transfer datas :
-Nokia mode (it use the software Nokia PC suite OR ovi)
-UsB connect (it use windows explorer as an external disk)
-and an other mode that i haven't use yet.
*Voila :)
Bbye.
Denyzor
Jul 28, 2010 | Nokia 6300 Cell Phone
How to plug usb cables on the motherboard
Sometimes the USB connectors at the front of the PC are not attached. If someone can open the PC for you and see if there are wires inside running to those connectors that would be handy.
Feb 11, 2010 | Dell OptiPlex 160L (160LMIN) PC Desktop
2 usb plugs which goes where??? maxtor 120gb external hardrive pn9nx2dc-500
You have what is call a USB POWER Y ADAPTER: this is designed to provide extra current to your USB HDD drive from a second PC USB port. Plug the end with two USB connectors to your PC/LAPTOP and the single-ended plug to your drive.
Hope it helps! Let me know how you go.
Dec 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Anytime I plug something in to the USB port it give a error message that states, Power Surge on the USB port. What can I do to fix this?
The USB device could be drawing more current than the USB port can supply or the USB port may be faulty.
Get a powered USB hub and plug it into your computer's USB port and then plug the USB devices into the powered USB hub.
Aug 16, 2009 | Dell Dimension 3000 PC Desktop
I have a freecom 400gb external hard drive plugged in to my usb 2.0 port when i turn it on i get a message saying it will perform faster if its plugged into a usb 2.0 port any ideas
This means that although your hard drive is capable of handling usb 2.0 speeds, your PC has the older USB ports or if your PC has USB 2.0 ports, you don't have USB 2.0 drivers installed. You will most likely find USB 2.0 drivers from your motherboard manufacturers website.
Dec 05, 2008 | Computers & Internet
Where on my computer do I plug my camera into in order to upload my pictures?
  • Normally you would connect the camera to the pc using a USB lead. To do this your camera should have a mini USB slot somewhere and you would plug the mini USB cable plug in to this, then plug the larger USB end of the cable into one of the USB ports on your PC (USB ports are usually oblong and situated on the back of the PC) , You may need to install some software supplied with the camers to do so.
Please remember to rate this solution.
Oct 23, 2008 | Cameras
How to use a usb cable for the psp
Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
Scroll to the "Settings" icon on the home menu of your PSP.
Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
After that you can now transfer file from PSP to computer and vice versa...
Hope that helps..............
Sep 12, 2008 | Computers & Internet
Damaged usb port needs to be replaced on my HP Pavillion 513W computer. Need diagrams and step by step instructions
1-Shut down you pc .2-unplug the power cord.3-open the case .4-Find the usb wires trac them back to the board. 5-mark were the wires go with a marker.6-plug new usb port wires in.7-put the case back on pc.8-plug power cord in.9-turn on pc.10-plug your usb device in.
Jul 02, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
