Question about Brother IntelliFax-2820 Laser Fax
It just ring, ring, ring, but no fax come thru
The fax is set on manual and when I try to change to fax only didnt let me on the screen said DR mode in use I dont know how to change the mode without having this message
Thanks
  • Anonymous Nov 05, 2007
    Destintive ring
  • Brother Master
  • 1,113 Answers
DR = Destintive ring
This mode is set to on, you need it off, it's in the menu settings somewhere have a hunt or goto brother webite and get manual.
Posted on Oct 19, 2007
I HAD THIS MESSEGE IN MY SCREEN ~DR MODE IN USE ~ THAN I PUT IN GOOGLE AND THERE GO I FOUND A SULOTION THANK YOU I HAD THE PROBLEM SOLVED
I PUSHED MENU/SET THAN 2-FAX THAN 0.MISCELLANEOUS THAN 2-DISTINCTIVE I TURNED IT OFF
PERFECTTTTTTT
Posted on Nov 05, 2007
Manual on how to fax on the canon MX340
set up for fax reception the following four modes are available for receiving faxes. select a receive mode according to your needs. you can change the receive mode any time. refer to the on screen manual basic guide. A CALL RING PATTERN DETECTIVE SERVICE (DRPD/NETWORK SWICH) MAY NOT BE AVAILABLE DEPENING ON THE COUNTRY OR REGION OF USE. TEL priority mode- FAX priorty mode- FAX only mode- DRPD/network swich.
press the FAX button then press the MENU button ( the fax setting screen is displayed) use the left or right button to select RECEIVE MODE SET., then press the OK button ( the receive mode set . screen is displayed ) select a receive mode then press the OK button ( the select receive mode is sdisplayed )
Jul 12, 2011 | Canon PIXMA MX340 Wireless Office...
Intellifax 2820
DR mode means that the distigntive ring feature has been activated so it will not let you change receive mode. You need to turn off DR first. Press menu/set then 2, 0, 2, then press the down arrow till you see distigntive off then press menu/set.
Now you should be able to change the receive mode to fax only!
May 29, 2010 | Brother IntelliFax-2820 Laser Fax
Can't set mode to receive fax, read through manuel says DR mode in use. fax does'nt pickup when a fax or call comes in stuck in manual.
DR MODE is in use means that your machine is setup with the distinctive ring feature, to turn it off follow the directions below.
Turning off the Distinctive Ring
1 Press Menu/Set, 2, 0, 2.
2 Press ▲ or ▼ to select Off.
Press Menu/Set.
3 Press Stop/Exit.
Then you will be able to change the receive mode.
Apr 16, 2010 | Brother MFC 210C All-In-One InkJet Printer
Fax is stuck on manual mode. how can I change. When I try to change modes, is says that DR mode in in use.
I had this problem too, I just fixed it! DR = DISTINCTIVE RING, this means you have it turned on. To turn it off go to menu, fax, miscellaneous, distinctive and select OFF. Now go to back to initial setup and select your mode!
Mar 03, 2010 | Brother MFC-440CN InkJet Printer
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
MFC 465 CN - says FAX in DR Mode...What is that?
DR mode is distinctive ring, you have to go into fax setup and step through the options. If you go to print reports and select user settings the report will tell you what it's set for and the options are found in the same order they are printed.
Jun 24, 2009 | Brother MFC-465CN InkJet Printer
Brother Intellifax
Not familar with MNL, does sound like you have the receive mode set to manual. set to auto anser or answer machine. In manual mode the phone will ring until you tell the fax to receive. In auto mode after so may ring which you set, the fax will pick up...
Aug 28, 2008 | Brother IntelliFax-2820 Laser Fax
Mfc 8460n dr mode in use
The message DR mode in use or BT Call Sign On will appear on the display of the Brother machine if you attempt to change the receive mode from Manual to another mode when the Distinctive Ring feature (BT Call Sign) is turned ON. If you want to change the Receive Mode, set the Distinctive Ring feature (BT Call Sign) OFF.
  1. Press Menu or Menu/Set.
  2. Select Fax => Miscellaneous or Tel Service => Distinctive or BT Call Sign.
  3. Press the Up or Down Arrow key to select off. Press OK or Menu/Set.
  4. Press Stop/Exit.
Jul 16, 2008 | Brother Office Equipment & Supplies
Fax will not recieve
DR mode means that Distinctive Ring is set to on which will force your fax machine to manual receive. Turn DR off and you can set it to whatever mode you want.
Nov 03, 2007 | Brother FAX-575 Plain Paper Thermal
Brother IntelliFax-2820 Laser Fax Logo
1,317 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
