Question about Epic 400 Mx Treadmill
Remove front roller - Epic 400 Mx Treadmill
    Problem Solver:
I found a much easier way to remove the front roller. Here goes:
  1. Remove the cover
  2. Loosen the back roller. Turn each hex screw at the end of the treadmill about 10X or so. Make sure you keep count so you can tighten each side the same number of times when you are finished.
  3. Use a screwdriver to unhook the spring that holds the tension pulley to the frame
  4. Remove the drive belt from the motor pulley.
  5. Now this is the tricky part. The axle of the roller is just about the exact size of the hole in the frame in which it rests. The axle has a little notch about a half inch from the end that is a smaller diameter than the axel. The notch settles on the ridge of the frame and keeps it from moving side-to-side. You'll need to grab each end of the front roller and lift up and try to align each end of the axle with the hole in the frame. It might take some wiggling. Gently press away from the pulleys as you are doing this. When both ends line up one end will go further into the frame, while the end with the pulleys will slide out of the opening altogether.
  6. Once this happens, you can lift up on the end of the roller with the pulley and slip the old belt off and put the new belt on.
  7. Slip the axle back into the frame opening until it locks back into place.
  8. Put the belt around the roller pulley, under the tension pulley and around the motor pulley
  9. Using needle nose pliers, grab the spring and reattach it to the frame.
  10. Replace the cover
  11. Viola! Hope this helps.
Posted on Dec 13, 2014
The only way I found to remove the front roller was to disconnect the right side hinge (watch you fingers, it's under lots of force). Then clamp a pair of vice grips on the roller axel between the roller and support. Then use a crowbar to pry the axel (between the vice grips and base support) from the support. Make sure you disconnect the bottom plastic on the right side to avoid breaking it. Reassemble the same way. You will need quite a bit of force to reconnect the hinge. I used a ratcheting tie down to align the holes (pull the right side deck and the right side base together). There must be an easier way but I have not found one yet since the roller supports are a continuously welded u-shapped frame.
Posted on Sep 21, 2014
How do I get to drum rollers kenmore he2
Lift top and tilt back, remove 2 top screws and 2 bottom screws, remove wires from door switch, lift front up a inch and pull out of drum and set front off to the sides. Rollers are attached to rear panel, remove roller retainers, and replace rollers, then reassemble.
Jul 26, 2015 | Kenmore Dryers
I have nordictrack A2105 and although we "oiled" the belt and replaced motor belt, it still slips. What are we doing wrong?
remove the hood. Turn the treadmill on to speed of 4 or 5 and straddle the walk belt. While the treadmill is running (with good shoes on) step hard on the walkbelt while observing the motor belt and front roller belt pulley. Does just the belt or front roller stop? if so the belt is loose. If the belt does not stop check to see if the front roller stops and the front roller pulley keeps going. If so the front roller pulley is slipping on the roller. If the belt, pulley and front roller are all moving and the walkbelt is the only thing that stops when stepped on then the walk belt is loose. To repair a slipping front roller you have 2 options: 1) purchase a new roller assy or 2) loosen the motor belt and push it to off to the side of the front roller pulley (no needto remove). Realign the roller pulley to the motor pulley. You may have to tap it into alignment. On the inside section of the grooved part of the pulley drill an 1/8" hole thru the pulley and thru the roller housing. (If you drill to the outside portion of the pulley on the left hand side you will hit the roller bearing. Now take a larger drill bit like a 3/8" and lightly countersink the plastic pulley - try not to drill thru the pulley with the larger bit. Using a thin head sheetmetal screw, install the screw so the head is just below the ribbed surface of pulley. If you screw up your first attempt just rotate everything 90° and try again.
Nov 11, 2014 | Nordic Track Nordictrack A2105 Treadmill...
I need to replace the motor belt but i can't remove the front roller of my H140t Healthrider treadmill
There is one screw in the front roller
  1. Loosen the rear roller
  2. Remove drive belt
  3. Remove the 1 screw in front roller
  4. Pull roller out
Jan 01, 2014 | FreeMotion HealthRider "Club" Series H140t...
Belt stops running although you can hear motor running. How do you replace front roller pulley?
Loosen off the rear roller adjustment bolts, 10 turns each side counterclockwise.
Remove the motor drive belt.
The front roller should now be removable. If you have difficulties, back off the rear roller adjustment bolts 3-4 turns further. Keep track of how many counterclockwise turns so you are able to readjust the belt after replacing the front roller pulley assembly.
Repeat the instructions in reverse once the front roller is in position.
Dec 16, 2010 | Epic View 550 Treadmill
Replacing the drive belt Nordictrack 2900
basically you will be just about to take your treadmill, almost totally apart. But the are not many nuts and bolts to solving your problem, first Lay treadmill on its side and locate the rear roller bolts, on mine their are 2, most tread mills are all the same, remove them 2 bolts, Now locate the front roller bolt, 1 bolt,remove bolt, your belt is going to be very loose now, on the side that you would be walking on, Is a board, 6 phillips head screws, Hold the board to the metal frame, remove them, remove the board, then go back to the rear roller, And remove the plastic end caps that hold the rear roller too the metal frame, by gently tapping them off, remove old belt from rear roller, Now go to front roller, and remove belt from front roller, and its time to Install new Belt, AND AJUST NEW BELT, Put belt on front roller and reinstall roller, put plastic end caps back on frame, and then reinstall rear roller threw the belt and reconnect to the plastic end caps on the rear of the frame, Now reinstall the board with 6 phillip screws, to the metal frame, Now turn treadmill upright again, Its time to AJUST YOUR NEW BELT 1st Center your New Belt, Then tighten rear roller bolts, ( Pay Attention ) Count even amount of turns for both Rear roller bolts, Then Ajust front roller Alignment, Their is only 1 bolt on most treadmills, So if your belt is pulling to one side when you turn the treadmill on,it means you still have to ajust the front roller ajustment screw, What I Do Is , I USE A small leveling tool, For the front roller ajustment, It KEEPS the pitch EVEN on both sides of the front roller, and this is HOW YOU REPLACE YOUR BELT AND AJUST THE NEW BELT, and save your self some money, enjoy, in you need to contact me, kjosr@cox.net
Oct 24, 2010 | Nordic Track /proform Treadmill...
How do we take the back off of the dryer?
After the top is removed, the front control panel, then the front panel, then the drum is removed to get to the rollers.
The back of the unit cannot be removed to remove the rollers.
Jul 25, 2010 | LG DLE5932W Electric Dryer
The treadmill is loose. How can this be fixed?
If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Follow this procedure: First remove the key and UNPLUG THE POWER CORD. remove motor shroud, then find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability.
If your treadmill is not equipped with a bolt as described above, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt Tighten the bolt and test. If the problem is not corrected, repeat steps above and retest.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. Follow this procedure:
First remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Rear Roller Adjustment Bolts
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley and front roller must be replaced.
Follow this procedure: First remove the key and UNPLUG THE POWER CORD. remove motor shroud. Loosen the rear roller and remove the two adjustment bolts. Some models have a spring loaded tensioner on the right hand side so be careful when removing these bolts. After the bolts have been removed, remove the rear roller end cap(s). The rear roller should now simply slide out of the walking belt.
Remove the motor hood. Using a black permanent marker, make a mark on the front roller adjustment bolt on the motor compartment side at exactly where it fits flush with the roller so you will know where to retighten it later. The adjustment bolt is on the right hand side of the front roller. Then remove the bolt with a 7/16” wrench. then remove front roller and replace with new reverse procedure mentioned above
May 16, 2010 | Proform Sport 1000 Folding Treadmill...
Change rollers
Hello, Unplug dryer from wall remove filter at top remove 2 screws under the filter, take flat screw driver pry top up on both sides at the front. With top up remove 2 screws that hold the front panel to the cabinet now the front panel can be put to the side. release tension from belt and remove the drum. Now the rollers are right in the rear and they support the drum. change rollers and reassemble. good luck
Dec 26, 2008 | Kenmore 63942 Dryer
GE dryer is getting louder when running
most common cause is the failure, or wear of the rollers at the rear,
the drive belt places a lot of torque on the drum, and it has rollers to support this force, in addition to nylon guides as the front has
good roller
worn roller
most dryers access from the front, the front panel and door come off,
here are generic removal instructions
with dryer unplugged examine lower front panel.
If there are two screws at lower corners
  • remove screws
  • swing front panel up from bottom
  • unhook top clips
  • undo door switch wires
  • set panel and door aside
If there are no screws
  • remove llint screeen from top
  • remove 2 screws from under lint screen
  • with putty knife or other blunt blade
    push spring clips at front top corners
  • tilt top up
  • remove 1 screw each side 1/3 way from top of dryer
  • tilt front panel down
  • undoor door switch wires
  • set front panel aside
Common to both
  • reach under drum to belt tensioner, pull tensioner to end of spring travel
  • unhook belt from motor and tensioner
  • withdraw drum forward
  • examine rollers felts nylon guides
replace rollers in pairs if worn
replace nylon glides if worn
replace felts if worn, the back one may wear before the front one, if the dryer is the open drum type,
Oct 17, 2008 | Dryers
My Maytag dryer Model DE308 is very noisy. sounds like something is catching or grinding. can I fix this?
good roller
worn roller
  • remove screws
  • unhook top clips
  • tilt top up
Common to both types
Epic 400 Mx Treadmill Logo
167 people viewed this question
Top Epic Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
L Pfaff
L Pfaff
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
