Question about Horizon Fitness EX-59 Elliptical Trainer
Consol not working
Console will not turn on is this thing battery operated or is it static charged?
My Proform 6.0 ZE elliptical is draining new batteries within hours and humming. It makes LOUD popping and static sounds when using the AC plug in.
DEAR
AT FIRST YOU COUNT YOUR BAT AND MULTIPLY 1.5 THEN YOU USE A ADAPTER AC TO DC WITH SAME VOLTAGE LIKE 6 V OR 9V DC
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 21, 2017 | Proform Pro Form 6.0 ZE Elliptical
X box controller keeps turning itself off - I have put new batteries in
Connection problems might be caused by one or more of the following factors:
  • Weak batteries or a weak Xbox 360 Rechargeable Battery Pack
  • Interference from another wireless device, such as a microwave oven, a cordless phone, or a wireless router
  • Metallic objects positioned between the console and the wireless controller, such as a chrome faceplate or metal dividers, shelves, or doors on an entertainment center cabinet
    Note All licensed Xbox 360 console faceplates are tested for interference, and do not interfere with licensed wireless devices.
  • There are already four controllers connected to the console.
uparrow.gifBack to the top THINGS TO TRY Solution 1: Restart your console Turn your console off, wait a minute, and then... Solution 1: Restart your consoleTurn your console off, wait a minute, and then turn it on again.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 2: Replace the batteries or the Rechargeable Battery PackInsert fresh AA batteries, or attach a fully charged Xbox 360 Rechargeable Battery Pack to your controller. If you have an Xbox 360 Rechargeable Battery Pack
  • Remove the battery pack and reattach it to your controller, making sure that it is attached correctly.
  • Press and hold the Xbox Guide button. In the upper-left area of the Xbox Guide button, the battery meter indicates your current level of battery strength. You might need to recharge the battery pack, if the level is low.
If you have an Xbox 360 Play & Charge kit
  • Make sure that the Xbox 360 Rechargeable Battery Pack is correctly connected to your controller and plugged into one of your console's USB ports. If you check both of those things but are still having the problem, try the suggestion below.
  • Plug the charge cable into each USB port on your console, one by one. There are two USB ports on the front of the console and one on the back. If the controller works in one USB port but not another, try another accessory in the USB port that did not work with the controller. If the USB port does not work with any accessory, your Xbox 360 console might need to be repaired.
  • Turn off vibration feedback (rumbling) on the controller. If you play games with feedback while charging, it takes longer for the controller to charge and might drain the battery pack faster than it can recharge. Here's how to turn vibration off.
    1. Press the Xbox Guide button on the controller.
    2. Go to the Settings area, and then select Preferences.
    3. Select Vibration.
    4. Select Enable Vibration to clear the checkbox.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 3: Remove objects between the controller and the consoleThe controller works within 33 feet (10 meters) of your console. However, objects placed between the controller and the console might reduce this range. In addition, objects that use wireless technology (for example, a cordless phone) can interfere with your wireless controller. Remove or relocate objects or wireless devices that might interfere with the wireless controller or console. Here are some things that can cause problems:
  • Microwave ovens
  • Cordless phones
  • Wireless routers
  • Chrome faceplates
  • Metal dividers
  • Shelves
  • Doors on an entertainment center cabinet
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 4: Disconnect all controllers and headsetsIf all four rings surrounding the power button on the console are green but the controller has four flashing green lights, four controllers might already be connected to the console. Disconnect all of the controllers, and then try to connect the controller with the problem.
  • To disconnect a wireless controller, press and hold the Xbox Guide button for three seconds, and then turn the controller off.
  • To disconnect a wireless headset, turn the headset off.
  • To disconnect a wired controller or headset, unplug its cable from the console.
To learn more about connecting your wireless controller, please read the following Knowledge Base article: 906947 (http://support.microsoft.com/kb/906947/ ) How to connect an Xbox 360 Wireless Controller to an Xbox 360 console or computer If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 5: Replace your controllerIf your controller still does not work correctly, it might need to be replaced. Please contact Xbox support at the following address: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) uparrow.gifBack to the top Additional supportPlease visit the following Web site for information about how to contact Xbox support: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Dec 05, 2010 | Microsoft Xbox 360 Controller
Battery seems to be charging properly, but sometimes the console won't power up when switched on
if it also turns on for no reason at all then the same thing happened to my friends she fixed it by turning the ds to the back and peeling off the sticker that was on her battery lid thing
Apr 08, 2010 | Nintendo DS Lite Console
Xbox 360 wont charge play and charge kit
First thing to do is check your USB ports on the console. Plug in a flash drive or anything into all 3 USB ports to test them. If they all work you have eliminated the console as the source of the problem.
Alternatively, if you believe it may be the play and charge kit itself, simply plug it into any usb on any pc with a controller attached. If the red charging light turns on, it is working properly.
If both check out it simply means it's time to replace the battery pack in the controller. They have a life cycle depending on usage, and they vary greatly.
Dec 23, 2009 | Microsoft Xbox 360 Console
360 controler not working properly
The batteries might be low. If you're using the rechargable batteries they might be bad. I've had some of my rechargable batteries go bad after only a few hours of gameplay and one charge. If their within one year old microsoft will replace the batteries at no charge.
Sep 14, 2009 | Microsoft Xbox 360 Console
My PSP Light Turns Green, But wont turn on.
try charging it for a FULL day. if that dosent work replace the battry with a new battery from best buy or something
Jul 14, 2009 | Sony PSP-3000 Silver Console
When i turn on my psp it does not work and if you try to turn it off it does not work...I tryed taking out the memory stick snd the umd and it still does not work...i also tryed to hold the R button while...
have you tried the battery if you have then the best solution here is to get it checked out because there isnt a lot we can do without looking at the thing personally which won't happen. Also make sure it is cleaned out from dust because that is sometimes a main cause of console faults. Hope i helped!
May 01, 2009 | Sony PlayStation Portable (PSP) Console
Charge light orang on for a second and turn off unit not charged.
This kind of problem is usually caused by either of this 3 things: Either the problem is the battery not being able to charge anymore(bettery would need to be replaced), or the charger does not give any charge to the batter(recommend try another charger), or last would be the console charger port( would need to replace console, or repair charger por,not recommended)
Mar 10, 2009 | Nintendo DS Console
Psp won't stay on
How do you know the battery is fully charged ? Repeat this operation with someone else's battery and see what happens...
Nov 30, 2008 | Sony PlayStation Portable (PSP) Console
Horizon Fitness EX-59 Elliptical Trainer Logo
77 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
