Question about Kitchen Ranges
FGFL87DCF has an error code f13 - Kitchen Ranges
3 Suggested Answers
  • 37 Answers
SOURCE: F13 error code on Miele dishwasher. I can't find
The water valve on Miele dishwashers is built into the end of the water line where it hooks into your plumbing(in that box-looking assembly) Your best bet is to call Miele USA, I have had very good luck with their customer support system, they can usually diagnose your problem right over the phone.
Technical Support
Residential Appliances Hotline
(800) 999-1360
Monday-Friday: 8:00 am - 8:00 pm EST Saturday-Sunday: Closed
http://www.mieleusa.com/usa/contact/contact_miele.asp?page=1
Posted on Apr 20, 2010
anurag50400
  • 3 Answers
SOURCE: What is error code f13?
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad. This can be caused by a power surge or glitch through the electrical lines. You can try to reset the control board by completely unplugging the range (or shutting off the breaker) for 5 minutes. If the error code returns after plugging the range back in, then the control board for the range will need to be replaced.
Posted on Feb 05, 2015
F13 and F11 codes pop up
F13 is
Dispenser Circuit Error
If the dispenser motor is not able to be driven to it's proper position.
Check mechanical linkage from dispenser motor to the top of the dispenser
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
i snagged this answer from another site
i think its a worn bit of plastic
as it becomes britten when not always wet
much like a boat out of water
Mar 05, 2015 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Feb 05, 2015 | Thermador C301U Electric Single Oven
Frigidaire fault code f13 kitchen range what does that mean ?
Thank you for your inquiry, raymond bouley!
I understand that your Frigidaire range is displaying an error code of "F13". An "F13" error code typically stands for a bad EEPROM (Erasable Programmable Memory) identification or check sum error. The best way to clear this code is to disconnect power from your range for roughly ten minutes. If you continue to experience an issue it could be a possible that you have a faulty board or wiring harness. I would then recommend having a professional out to perform a diagnosis on your range. Hope this helps. -Matt
Jan 13, 2015 | Frigidaire Kitchen Ranges
F13 code
Hello friend, thank you for your post!
Based off the information you have provided your question is under an "F13" error code but you also stated that it is showing you an "F1" error. I have researched both error codes for you. "F13" usually indicates error identification, which could be an issue within your control board. "F1" typically can indicate that the range has detected an issue with the runaway temperature (overheating). Both codes could be corrected with a reset, which you can do by flipping the household circuit breaker for roughly ten minutes. If that does not correct the issue I would recommend contacting a professional. I hope this is helpful. -Matt
Aug 07, 2014 | Frigidaire Ovens
Error code F13 Bauknecht washer front loading
error codes washer machine bauknecht f13
Nov 15, 2011 | Washing Machines
F13 error code on Ariston washer dryer combo
Model ARMF 125 with same error code F13 how to fix please advise Thks
Nov 06, 2011 | Hotpoint-Ariston ARWDF129NA Washer
What does F13 Error mean?
Here is what the F-13 error code means and the fix for it.
F13 Internal CPU checksum errors 1. Disconnect power for 1 minute.
2. Reconnect power.
3. If failure remains, replace the touch control module
So it says the main computer control had detected a error in the touchpad control
I hope this helps,
Gene
Aug 01, 2011 | Kitchen Ranges
I get a error f13 when i turn on broiler
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx
Above are the codes and meanings.
The "F13" error code means "Bad EEPROM identification/Checksum error".
If reseting the power does not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
- The part number for the EOC is AP3874704
Dec 13, 2010 | Frigidaire Kitchen Ranges
My AWOE8748 had a fault code F13. It has now switched itself completely off.
F13 indicates "Dispenser Circuit Error" in your washer.If the dispenser motor is not able to be driven to it's proper position this error code appears.Check mechanical linkage from dispenser motor to the top of the dispenser. The wire harness connections to the dispenser motor and Central Control Unit (CCU) would have been faulty so check for those.Also do a final check on dispenser motor.
Thank you !!
Jun 20, 2010 | Whirlpool AWOE8748 Front Load Washer
My kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Jul 09, 2008 | Kitchen Ranges
Kitchen Ranges Logo
12 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
